      04-16-2019, 06:24 AM   #419
JP10
JP10's Avatar
Drives: M3
Originally Posted by lsturbointeg View Post
I always wondered how that would taste? Did you use milk or water?
Unfortuantely water.. I miss when I could use milk without it thrashing my stomach, made the shakes so much better lol
      04-16-2019, 07:54 AM   #420
joshe92
joshe92's Avatar
Drives: 2017 F80 M3
Originally Posted by JP10 View Post
Just for the record I'm mad you wear workout gloves lol.
In the past I used wrist wraps but I think they actually caused some pain for me. I don't lift heavy enough to feel the need to use lifting straps. I never actually tried the gloves, I'm just hating because Im not about the way they look haha.
As for gym talk I'm pretty mad that when I eat in excess I feel worse yet I looka and feel pumped up and my lifts are so much better. When I eat healthy I lose weight, feel better, but also feel and look flat as shit in the gym also my lifts are much worse. I am constantly bouncing between 190 and 200lbs depending on how I want to eat that week. It's tough finding the perfect balance without going overboard on either end.
Tough question since back pain is pretty vague and there can be numerous issues. Just stay away from movements that cause you pain. Even if the movements you're doing are rather basic or easy, just working your core has a lot of benefits.
Use harbingers
2017 F80 M3 competition Sakhir Orange: // ER catless downpipes, // AA EL midpipe resonated, // MHD tune
Retired: E92 335i MSport Sapphire black: // aFe intake // Remus quad // AR Downpipe, Secondary cat delete // MHD // BMW PPK // Alpina B3 Flash // Vrsf 5" Stepped IC & CP
      04-16-2019, 11:29 AM   #421
UncleWede
UncleWede's Avatar
Originally Posted by Germanauto View Post
Past one week I'm suddenly at 169 lbs.
The only change to my diet from my cut
Not always considered "diet" but how much water are you drinking? 3 lbs is under 1/2 gallon of retained water. Need to drink MORE so that your body is comfortable that there will be an adequate supply all the time, and not try to hoard it.
Also, WHEN are you measuring your weight? Time of day, you naturally fluctuate.
Germanauto9704.00
      04-16-2019, 11:50 AM   #422
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Yeah good point I pick up 3-4lbs every day. Gone in am between growth, respiration and excrement hopefully not in bed.
      04-16-2019, 12:24 PM   #423
Germanauto
Germanauto's Avatar
Drives: Alfa Romeo Giulia, Rosso
I think I am a little low on water consumption.
And I usually take my weight after sh*tting. It came out at 167 this morning which is a good weight. The other day when it came out to 169 I had only taken a small chit.
Former
-2008 E90 328 black/brown
-2012 Lexus IS250 black/black
      04-16-2019, 12:30 PM   #424
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
it's always good to drink water throughout the day. i'm not sure how much I drink but I know i'm constantly in and out of the bathroom all day at work. if your piss is clear that's good. if it's yellow than you need more water
      04-16-2019, 12:30 PM   #425
Rmtt
Rmtt's Avatar
Drives: 2011 BMW 128i, 2008 LS3 C6
The guys above hit on everything, you just gotta keep at it. I wouldn't worry about the weight aspect too much unless you start to see that you're putting on fat in unwanted areas. People tend to get hung up on that but it's just a number. For instance Tuesday last week I was 191, by Friday I was 198 without feeling much of a difference at all. Weight can fluctuate, it is what it is, what matters is eating health consciously while ensuring that you're getting enough nutrition to grow (if that's your goal).
Form, ancillary muscle developement, persistency.
Side note got the chocolate caramel pretzel protein flavor yesterday in the mail, didn't taste any caramel or pretzel but I did mix w/ peanut butter, still tasty tho.
+1.
You want muscle growth, you have to be in a calorie surplus unless you are just starting out and a newbie to lifting. It's a fine line we walk between eating enough calories to trigger growth, but not get too fat in other areas.
Also as you get heavier, your body will gravitate towards partitioning your extra calories to unwanted areas. It's called a "P-Ratio". (Partitioning Ratio). You can affect this to a certain bit such as how you combine your foods, but you will reach a point where you have to slow down....sometimes painfully slow.
I find that if I get above 12%, my body shifts towards putting fat on a little more easier. But I'm lucky in that my body-fat is distributed more evenly.....so I can still see abs at 12%.
As for any exercise you want to progress at....you just have to work that exercise. Make sure you are using proper form, and then work every variation of it. You get better at it by performing it.
And as someone else mentioned....Lats play a major role in Bench Pressing. If your back is weak, your bench will stop progressing at some point. When you bench, you aren't just using your pectoral muscles. You are using lats and triceps if you are setting up the right way.
You have to learn how to engage all of these even if it means lowering the weight and learning the proper form all over again.
Then repeating the process over and over. It's taken me 15+ years to get to the point of where I am at currently. And the last 5 years have been more focused on diet than anything.
JP102465.00
      04-16-2019, 12:32 PM   #426
Rmtt
Rmtt's Avatar
Same here.....I can gain/lose 5lbs between morning and evening.
      04-16-2019, 12:34 PM   #427
lsturbointeg
ooooooooooooooooooh can't wait!!! it's back/bi day today!
      04-17-2019, 06:32 AM   #428
JP10
JP10's Avatar
Drives: M3
ARM DAY!! T-minus 7.5 hrs, can't wait honestly! Arm day is a damn treat and you all know it
      04-17-2019, 11:28 AM   #429
Rmtt
Rmtt's Avatar
I only use water now...but when I did use milk I had the same issue. One thing that helped was getting those generic lactose tablets. You get like 30 of them for about 5 bucks at a local grocery store.
Chew one up about 5-10 minutes before your shake, and I had no issues. Never use to be lactose intolerant .... but as I've gotten older it started affecting me.
But I used those pills with great results for a couple of years before cutting milk out of my diet.
      04-17-2019, 11:30 AM   #430
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
I use milk and have lot of dairy besides as well. No problem
      04-17-2019, 11:30 AM   #431
Rmtt
Rmtt's Avatar
I have chest and biceps in the morning.
Programming has my last few sets of flat bench in the 365 range. I haven't been in that range since last years charity bench contest at my gym!
      04-17-2019, 11:31 AM   #432
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Dis light chest last night to give shoulder some rest, single sided stuff try to even out my manboobs
      04-17-2019, 11:33 AM   #433
Rmtt
Rmtt's Avatar
It's odd for me. Cheese, Ice Cream don't affect me. A lot of milk leaves me feeling like "bleh".
But now I can use that one organic high protein milk that's out and have no issues.
But since I only have an Intra with unflavored hydrolyzed whey, and a post shake with unflavored hydrolyzed casein....I just use water. Any other time I'm eating whole foods.
      04-17-2019, 11:56 AM   #434
UncleWede
UncleWede's Avatar
Had a decent 3.7 run last night, but my blood sugar crashed about 1 mile out (and my new CGM was buzzing the whole time) It's tough to finish strong with no sugar to feed the muscles.
June 6 I'm carrying the Special Olympics torch again!!!
TomHudson659.00
      04-17-2019, 07:23 PM   #435
lsturbointeg
Can I say thank you to who ever I invented thongs and yoga pants! cause talk about eye candy tonight! I kid you not everywhere I looked there were hawt chicks everywhere!
      04-17-2019, 07:30 PM   #436
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Took tonight off carb loading with ipa instead
      04-18-2019, 07:51 AM   #437
FlaPatsFan
Drives: 2011 328i wagon
You are supposed to drink half your body weight in ounces a day. That is without exercise. I’ve been drinking hydrogen water during and at end of my workouts lately. My recovery has been much better!
      04-18-2019, 07:52 AM   #438
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Water already is hydrogen and oxygen. Snake oil.
      04-18-2019, 08:07 AM   #439
FlaPatsFan
This is worth reading 1MM
https://www.alkaviva.com/benefits-of-hydrogen-water?
      04-18-2019, 09:27 AM   #440
JP10
JP10's Avatar
Drives: M3
I'm the same way, cheese and ice cream are not issue at all. I use to drink so much milk too, but anymore I just don't feel the best after. I haven't had any experience using organic high protein milks, I'll keep my eye out for them.
Can't believe you go unflavored, I look forward to my shake everyday because it's mighty tasty and easy to stomach. 12oz water, handful of ice cubes, scoop an half of protein, and a heep of peanut butter all blended up, so damn good haha.
