09-26-2018, 09:16 AM | #2 |
Rep 2,906
Looks like those are for the GC and F12/13M, so the broader question is whether GC or M wheels fit a 650. It looks like the offset is 7mm different front and rear. I think a 650 uses the same offset on all four. But I assume somebody knows if M wheels fit a regular 650.
09-26-2018, 10:56 AM | #3 |
Rep 909
I found this site as I was also looking myself to check compatibility of some alternative wheels with my F06 LCI model.
https://www.wheel-size.com/calc/ I like it as it lets you compare both the OEM setup as well as the one you would have with the alternative wheel model you are considering. The 408M wheels are originally meant for the following series (M5 & M6 cars): F06 F10 F12 F13 Last edited by FBMWWINS; 09-26-2018 at 11:06 AM.. |
09-26-2018, 11:00 AM | #4 |
Rep 7,480
The f06/f12/f13 (Sedan/Vert/Coupe) all share the same wheel offset range (I6 & V8)...except the M versions. The 408 wheel style is the winter wheel BMW offered for the M5 (f10) & M6 models (f06/f12/f13)...and has a 32mm (front) 25mm (rear) wheel offset.
I would run those specs through a site like www.willtheyfit.com to see how those specs fit compared to the BMW oe wheel specs for the non M models.
09-26-2018, 02:54 PM | #6 |
Rep 7,480
Is the second image for the rear wheels? Will that 5.4mm toward the suspension cause rubbing under load (extra passengers) or while turning etc? If yes, then perhaps extra consideration as to if you should use that wheel/tire combo on that axle should be questioned. Or would the use of wheel spacers be something you want to consider?
