      04-14-2019, 10:36 AM   #1
Sonny Crockett
Sonny Crockett's Avatar
Sweden
45
Drives: 640D X-drive M-sport
USB in the armrest
Hello, the USB connection in my armrest is not functioning properly anymore. Is there anybody who can say how to remove it without dismantling the whole armrest and center console?
It doesn't matter if the current USB connection breaks in the process...
Thanks!
      04-14-2019, 11:14 AM   #2
Cincinnatus
Drives: 2013 M6
You're going to have to remove the right panel of the center console (where the iDrive controller sits) to get to the USB port. These instructions from another member sent to me for installing a new display may help, Obviously, disregard the steps for the dash trim.
Originally Posted by hugo_nz
Your install should go something like this:
1) disconnect battery negative terminal
2) move front seats all the way back and move backrests back as far as they can go
3) remove small carpet trim
4) remove side trim
5) remove dash centre trim/vents
6) remove idrive screen
7) remove climate panel
8) remove CIC unit
9) remove wood trim on centre console/gear surround
10) remove leather centre console cover
11) hook up wiring harness, route cables
12) install new screen
13) test
14) reassemble
Carpet trim: LINK
Side covers: LINK
Centre console wood trim (gear surround): LINK
Idrive controller trim: LINK
Dashboard centre trim (vents): LINK
Idrive Screen: LINK
Radio AC panel: LINK
CIC Unit: LINK
Challenges/Observations:
* Two of the T20 torx on the side trim can be a bit tough since you either have to peel back the plastic trim or remove it
* Routing cables under the center console carrier. Not so much a challenge as it is time consuming
* Cable management. While there is plenty of space behind the CIC you may still have to fiddle a bit to make everything fit. I found moving most of the cables to the glovebox side helped a great deal
* Cover all the leather surfaces. There are many sharp edges that may come in contact with them during this install and you don't want to ruin the leather.
* The original tape binding some of the cables together will have become sticky with age. Just wear gloves.
      04-14-2019, 12:03 PM   #3
Sonny Crockett
Sweden
45
Ok, thanks! That is very clear instructions...I hope do dare and try it myself..but thank you again!
      07-20-2019, 02:15 PM   #4
worthywow
Drives: 640D M Sport Conv. 2014 F12
Thanks for this info - really useful. I want to feed in a USB cable into the centre armrest so hopefully I can get away with just removing the trim - fingers crossed !
      07-20-2019, 02:55 PM   #5
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
What are you connecting the USB cable to on the car side? The wood trim around the gearshift is simple enough to remove. As per my instructions above you can remove the driver side carpet strip on the transmission tunnel and then the couple of screws holding the wood trim down. This will expose the centre console carrier can the connector for the USB and aux in the arm rest.
      07-20-2019, 03:54 PM   #6
worthywow
I'll be connecting a phone holder to a mount on the front panel and then connecting the USB cable to the USB port.
https://www.brodit.co.uk/brodit/hold...e+9/721069.htm
I've used these Brodit holders for several years now - really expensive but they are precision engineered and well made so worth the investment.
Thanks for your tip - sounds like it might be easier than I thought !
      07-20-2019, 10:15 PM   #7
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
Attachment 2103408
Ah ok. You'll need a long cable :-) for the cleanest install you could run the cable behind the climate panel and down along the centre console to the arm rest.
Which version of iDrive is fitted? CIC, NBT or EVO?
      07-21-2019, 01:27 AM   #8
worthywow
I've got NBT. Just checked and the cable length is 143cm so should be enough :-)
      07-21-2019, 03:08 AM   #9
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
Yes, BUT you can also connect a USB directly to the back of the NBT unit in the 2nd USB port :-)
I did this after I replaced my CIC unit with NBT. Both USB ports offer identical functionality.
      07-21-2019, 03:42 AM   #10
worthywow
That sounds like a very elegant solution Is it a standard Type A USB port ?
My only concern is there are a lot of steps to getting the NBT unit out - will just need to pluck up some courage !!
      07-21-2019, 03:47 AM   #11
worthywow
One question - I've done similar things on Volvo's and Merc's in the past and the clips were a big fragile when removing panels so had to replace a few clips (or live with a slightly wobbly panel !) How robust are the BMW ones ?
      07-21-2019, 04:10 AM   #12
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
The side panels are a mix of screw, slide clip and tension clips and they are pretty durable. I'd say a bigger concern is frequent screwing/unscrewing of screws into the plastic carriers etc.
      07-21-2019, 04:13 AM   #13
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
You need something like this: https://emtronika.com/index.php/product/bmw-cic-nbt-glovebox-usb-cable-with-socket-100cm/
Removing the iDrive is actually really easy.
Pull off the wood trim on the dash (no screws)
4 screws on the climate panel
4 screws on the iDrive
Pull it out
Easy :-)
      07-21-2019, 04:33 AM   #14
worthywow
Originally Posted by hugo_nz View Post
You need something like this: https://emtronika.com/index.php/prod...-socket-100cm/
Pull it out
Easy :-)
You've talked me into it !
Looking where to buy the cable I saw this which looks like it should do the job and is a bit cheaper
https://www.ebay.co.uk/itm/BMW-CIC-N...-/162643258706
Will feedback once I've given it a go !
      07-21-2019, 05:31 AM   #15
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
Yup that cable should work fine. At worst you may need to shave off one of the ridges but that's not a biggie..
I salvaged the glovebox USB from the CIC system when I did the NBT retrofit and mounted it in the cupholder
      07-21-2019, 05:45 AM   #16
worthywow
Neat ! I've not got a USB in the glovebox so have splashed out on the cable on ebay!
