08-06-2021, 07:37 PM | #2 |
Rep 2,907
Nothing specific, but don't go by the computer either. The computer is useless for brakes anyway, but that is a different story. The computer only covers a small number of things, and does not address spark plugs, coil packs, belts, suspension components, you name it.
I plan to do plugs at 50k miles. Change coil packs if you want. Check your engine and cabin filters if not replaced recently. But 50k is a good time for an inspection of you cannot do it yourself. Check for upper oil pan and valve cover gasket leaks. Check for coolant leaks, especially around the turbos. It's a heavy car, so have every suspension bushing checked. |
08-20-2021, 05:30 PM | #4 |
Rep 2,907
It takes 10 quarts of synthetic oil that meets the LL01 BMW standard. I DIY and use Castrol 5W40 which can be bought for about $35 per 5-quart jug. So even DIY the oil runs about $70. The filter will be $10-$15 depending on where you get it. To have a dealer or indy to do it will be over $100 for sure, but I don't know how much more since I have not been to a mechanic in years.
08-20-2021, 06:18 PM | #5 |
Rep 631
I usually get the 5Quart, but would like to find 5 gallons for $35. Nothing wrong with thinking big... I do my own oil changes as therapy. Takes about 1/2 hour and a beer.
F06 M6 Grand Coupe CP
08-20-2021, 06:57 PM | #6 |
Rep 281
I had an Indy do it that uses Liqui Moly. They applied a 25% Off discount and it was $110 out the door. And since I have 49K on it they did a courtousy inspection. My first time using this shop. Recomend plugs, coolant flush, cabin and engine filter. But I got that for FREE from Opie!
08-20-2021, 09:35 PM | #7 |
Rep 2,907
08-21-2021, 12:19 AM | #8 |
Rep 381
I have a contract with a dealership under BMW subsidiary- 3 years oil service including oil, filter and labor for $199. Manually reprogrammed oil interval to 5000mi and will come twice a year))).
08-21-2021, 08:30 PM | #10 | |
Rep 381
Don't look at computer, don't trust a car… Have you seen a service line car check? Or whatever they call it. Do you know what it does mean?))) |
08-22-2021, 12:10 AM | #11 | |
Rep 2,907
As for your last sentences, I cannot even guess what you are talking about. But whatever it is, it's not what I was talking about. Last edited by Opie55; 08-22-2021 at 07:46 AM.. |
08-22-2021, 08:03 AM | #12 |
Rep 458
08-24-2021, 11:36 PM | #13 |
Rep 451
Seems like a translation. But I get what they're saying
