      01-07-2022, 05:13 PM   #177
Artemis
Moderator
Artemis's Avatar
41430
Drives: BMW M2C - BMW X1
Originally Posted by jycf87 View Post
I'm not sure if you guys are looking into the details over your results after the VIN decoder but from what I've found, bimmer.work and others might work but aren't accurate. I looked up several different BMW's with DCT on Carvana with pictures, and the VIN decoders were pretty good on matching the colors but the transmissions noted from the decoder came out manual even though they were all DCT.
In 'BMW speak':
  • no torque convertor (such as 6MT and M-DCT) = 'manual'
  • torque convertor (such as ZF8) = 'auto'
Hence, VIN specs stating an M-DCT transmission as 'manual' is accurate (though, admittedly, a tad confusing).
Reposting post #179 of this thread clarifying that misconception.
Originally Posted by Artemis View Post
Originally Posted by tomwac View Post
As all the other decoders are dead, I tried MDecoder but it behaves strangly:
For my E28 628CSi with WBAEA3100B5571008 it says that it can't find any info
For my E61 545i WBANH31030B489526 it finds the info, but with some errors like it says it's a manual while in fact it's an automatic. All the rest is quite accurate on that car.
I wonder why it can't find my 628CSi
Originally Posted by Almuliman View Post
I've seen a lot of cars listed as manuals with the automatic as an add-on further down in the details. Agree it's odd, but it's been accurate where I've come across it.
"MANUAL"/"HECK" is indicated when the transmission does not feature a torque convertor.
Hence, within the BMW transmission ecosystem, in VIN specifications, for example an M-DCT will be indicated as "MANUAL"/"HECK" instead of "AUT".
Repost explaining this misconception:
Of course it would make sense to have 'the pedal count' as criterion (2 = automatic | 3 = manual) or the type of gear shifting (digital/electronic = automatic | mechanical = manual) or, simply, the possibility of automatic gear shifting (present = automatic | absent = manual). But for BMW, the torque convertor is the criterion (present = automatic | absent = manual).
M-DCT (code 2MK/S2MK/S2MKA in VIN specs | "M twin-clutch transm. with Drivelogic" | "M Doppelkupplungsgetriebe mit Drivelogic")
= no torque convertor = manual transmission in BMW's book.
Therefore, "MANUAL"/"HECK" (instead of "AUT") is indicated in VIN specs of any F87 M2. See also for example here.
See what is said from 01:12 onwards:
See also here from 01:55 onwards:
///M is art Artemis
      01-09-2022, 03:29 PM   #178
Onizukachan
Great Teacher
Onizukachan's Avatar
2344
Drives: 06 E91ix & ‘15 F31d
This is correct, automatics are fluid drive, manuals are gear drives.
DCT *is* a manual. Automated but still manual
‘06 E91 Manual 325ix BarriqueRot - over Terra (one of 1)
‘15 F31 M-Sport 328dx Mineralgrau - over Black (one of 94)
‘08 L322 Range Rover Rimini Red - over Sand (one of ? )
      01-21-2022, 03:09 PM   #179
mjn77
mjn77's Avatar
1993
Drives: E90 M3 LCI Jerez Black
2011 BMW M3  [10.00]
Originally Posted by Risay_335d View Post
Hi all,
Hopefully will be an F30 owner really soon. I've seen one I like but want to find the options it came with, I don't have the VIN , am I able to find out this info from the reg number?
Yes, but not easily.
What is reg?
//E90 M3 LCI DCT in Jerez Black / Fox Red Leather // Alcantara Trim // ST XTA Coilovers // 1.75 Exhaust // Pinnacle Undertray // IG @jerez.black.e90.m3 @bmwpcc //
Road Trips 2014 2016 2017 2018 2019 2022 2024 2024 2025 2025 2025
      01-21-2022, 03:10 PM   #180
Risay_335d
Drives: BMW 335D
Hi all,
What is reg?
Thanks for the reply, I managed to get the vin so have got the report . Thanks anyway
      02-20-2023, 01:48 PM   #181
Joachim
Joachim's Avatar
Germany
581
Drives: M4 Competition X-Drive [2022]
M4Comp Xdrive 2022: "Power 0kw / 0hp"
The fact is I don't drive just to get from A to B. I enjoy feeling the car's reactions, becoming part of it.
Enzo Ferrari
      03-30-2023, 12:49 PM   #182
Marcoose
Marcoose's Avatar
713
Drives: 2016 sDrive35is
Very useful thread. Thanks.
2016 35is, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
      06-12-2023, 12:08 AM   #183
ericold
Drives: e88 120
i read in an oil forum there are 3 different type of BMWs engine editions according to where you live on the earth .
there is a ''cold'' engine motor, a ''warm'' and one more ,he did't mention.
is it true and if it is how can we learn that? i mean if there is sthing written on the specs of the manual or in the engine area.
      06-12-2023, 05:12 AM   #184
cxyzs7
cxyzs7's Avatar
12
Drives: BMW X5
Used https://mdecoder.com and https://vinanalytics.com extensively during my search for X5. Need to switch to cellular network to avoid limited daily count for mdecoder.
nachob2393.50
pej7445134.00
MuXaH0.00
      06-12-2023, 06:39 AM   #185
Mikiee
Drives: 2002 CB M5, 2020 DG M5
2002 BMW M5  [0.00]
2020 BMW M5  [0.00]
I'm in the US and mDecoder shows two climate versions for my 2020 F90. S823 Hot-Climate Version an S842 Cold-Climate Version. No idea what the third version might be
2020 F90 M5 & 2002 E39 M5
2020 F97 X3MC
2018 G01 X3 M40I
1990, 1995, 2003 M3's
      06-12-2023, 08:13 AM   #186
ericold
Drives: e88 120
ok,i have the mDecoder open and i see all the specs. but can't tell where is that section/codes which show for what climate version. in which section you read these codes?
      06-13-2023, 04:13 PM   #187
ericold
Drives: e88 120
the third one is lets say , the normal or neutral version for central America and central Europe. i learned that there is one more for countries that drive on the right, uk and japan (cold), Australia and new Zealand( warm).
      08-10-2023, 08:39 AM   #188
Unpliable
Drives: 2014 X5 35i
mdecoder worked for me, but vinanalytics keeps asking for a valid VIN; tried with the full 17 digit and with the last 7 digits only, same result
      09-01-2023, 10:12 PM   #189
Gtirsmiley
Drives: 2017 X3
Interesting. Learned a bit. New to BMW's
      05-16-2024, 07:55 AM   #190
Randy Johnson
NFFA
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [9.90]
Couldn't get any of these decoders to work for my vehicle.
      05-16-2024, 08:39 AM   #191
ekinnee
Drives: 2021 M440xi Coupe, 2023 330i
If you're not using an ad blocker of some sort you're probably putting your vin in the wrong box or clicking the wrong button.
      06-08-2024, 08:27 AM   #192
BMWCCA1
BMW Owner Since 1971
2697
2013 BMW 128i  [10.00]
Originally Posted by RichardFraser View Post
Hi, I bought my first BMW the day before yesterday. Which decoder should I use? The car is 2017.
Have your local dealership service department run a Vehicle History Report for you. The MSRP report showing all options and pricing may only be available if they were the selling dealer, but the Vehicle History will give the same information without option pricing, as well as provide delivery date and warranty repair information. They should be happy to provide this at no charge and maybe impress you with their willingness to provide future service for your new BMW.
      06-08-2024, 08:47 AM   #193
visionaut
visionaut's Avatar
1704
Drives: 2016 435iX GC & 1976 2002
Since it’s your car, you can see all of its Features & Options listed under the "My BMW"> My Garage" link using your account at "mygarage.bmwusa.com". Use your ConnectedDrive userID/pwd.
      06-08-2024, 05:19 PM   #194
Artemis
Moderator
Artemis's Avatar
41430
Try each of the 4 referenced decoders in the first post. Those are free of charge.
A couple of weeks ago I processed a VIN and the http://www.bimmer.work/ one properly delivered.
As a matter of principle, references to decoder websites charging for VIN details are deleted in this thread. Hence, a possible later post stating "I tried decoder XYZ which was not free of charge, paid a fee and it worked", will be deleted as per the forum house rules ("8) No Commercial Posts or Activity. We have very strict Anti-spam policies here and we will be deleting posts/banning users without notice when the post is a commercial post made by a non community sponsor. If you happen to see these types of posts on the forum, we urge you to report these members to us. Commercial/advertising usernames, signatures, avatars, group buys etc. are reserved strictly for site sponsors.").
///M is art Artemis
JJ 911SC34338.00
      06-08-2024, 08:31 PM   #195
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
Yes, www.bimmer.work and www.mdecoder.com are the most popular. Sometimes bimmer.work can’t find the info and sometimes mdecoder.com will tell you you have gotten too many reports and to try again tomorrow even if you haven’t gotten a single report in weeks.
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
notice: I don’t suffer fools
___________________________________________
      07-29-2024, 02:17 PM   #196
amol24
amol24's Avatar
Drives: lmb 135i
if mdecoder is saying you reached your limit, using a vpn should bypass that. thats what i do when bimmerwork decides not to work.
      10-15-2024, 09:47 PM   #197
STi from DSM
STi from DSM's Avatar
1648
Drives: 2020 M850i GCX
This helped out a lot!
2020 BMW M850i GCX (Mineral White) 2025 Acura Integra Type S (Liquid Carbon) 2022 M850i Xdrive Gran Coupe (Twilight Purple) | 2019 Audi RS5 Sportback (Navarra Blue) | 2021 Audi S4 (Quantum Gray) | 2018 BMW M5 (Singapore Gray) | 2019 Audi RS5 (Mythos Black) | 2020 X3M Comp (Black Sapphire) | 2019 Audi RS3 (Mythos Black)
      10-22-2024, 01:31 PM   #198
tryingtobebest
Drives: E90
WHO remember when bimmer.work did everything in one page and can simply spit out a VERY VERY pretty PDF? Few years ago they changed it and now print to pdf is just not relevant, im trying to find a way to CONTACT them about it and maybe if somebody else is interested do a poll asking to switch back!
