      10-07-2023, 03:41 AM   #111
tr0tt3r
Drives: audi q5
Regarding Carplay not working I did this in my g30 5 series the other day:
“ Well my gf just told me she hold volume knob for 30s which resulted in system reboot (not factory reset). After that she just reconfigured her phone and it works fine
Lol she is smarter than I thought Thanks for help guys”
A post from 2022.
      10-07-2023, 04:52 PM   #112
oh-robot-nyc
oh-robot-nyc's Avatar
Drives: BMW X5 xDrive50e
I recently updated my iPhone 15 Pro Max to iOS 17.0.3. I got in the car (2024 X5 50e) for a two hour car trip and used the wireless charging mat. When I got out of the car, I had the dreaded message on my phone. Ugh.
      10-08-2023, 01:14 PM   #113
VirtualGuitars
VirtualGuitars's Avatar
Drives: 2024 BMW XM Label
Have any of you experienced this on an iX charging tray? No one has really said anything on the iX forum. It appears that many of you aren’t putting your vehicle model in your replies, so it’s hard to tell. Thanks.
      10-08-2023, 02:34 PM   #114
DrVader
DrVader's Avatar
Drives: 2021 BMW X7 M50i
Mine occurred on new XM
Thanks,
DrVader
      10-08-2023, 07:03 PM   #115
Dan B
Drives: 2024 M440i xDrive Gran Coupe
24 M440i, GalaxyS22 Ultra.
I just had the phone shut down due to a "thermal issue" after about 90 minutes of driving. I pulled the phone off the charger and it was baking hot.
I have not been able to determine if the heat impacted the battery but if it did, I will post it here.
      10-09-2023, 02:49 AM   #116
ramparts
ramparts's Avatar
1167
Drives: M40i
So, the current wireless charging bad has been superseded for new car production starting 30th October, when a new part becomes available.
Might be a coincidence of course, but interesting none the less
      10-09-2023, 09:17 AM   #117
Tejas1836
Tejas1836's Avatar
1044
Drives: 2023 X5MC Workmaster 75
Tagged
Two is One and One is None
      10-09-2023, 12:42 PM   #118
lindros2
Drives: 535i M-S
Originally Posted by RCtennis3811 View Post
Sometimes I wonder if it's because of the LTE signal booster built into our wireless charger that's causing something to go awry as I've been in rental cars with wireless charging (but no built-in LTE amplifier) that don't give me these issues.
Why in God's name would I want to boost LTE (4G)?
All of our phones (since 2020) support 5G.
Our other car has built-in LTE (like some BMW's ConnectedDrive) but the boosted signal strength appears to compensate for terrible speed (under 15Mbps).
2013 F10 535i Carbon Black M-Sport
2011 F10 535i Dark Graphite (Sophisto) Metallic (traded)
2009 Nissan GT-R (sold)
BMW CCA # 493835
      10-09-2023, 01:19 PM   #119
RCtennis3811
Drives: N/A
Most deployed 5G networks around the world require an LTE anchor for now.
2023 BMW M340i xDrive
2020 BMW 330i xDrive
2018 BMW X3 xDrive30i
      10-09-2023, 02:46 PM   #120
cochese
cochese's Avatar
56
Drives: X7 x40i
Curious where you saw this. Maybe too early to say, but will be nice if a new back can be retrofitted into existing cars.
      10-09-2023, 06:37 PM   #121
baron95
baron95's Avatar
1840
Drives: BMW G87 M2
Sometimes I wonder if it's because of the LTE signal booster built into our wireless charger that's causing something to go awry ...
What is this LTE booster that you speak of? What does it do and where is it located?
Is it a passive antenna repeater or an actual booster like a pico cell? (I can't imagine it is the latter)
I can tell you that a simple unidirectional (out to in) antenna booster is a bad idea, it boosts the signal from the tower, when it may be marginal, and causes the phone to transmit at max power since it is at the edge of coverage to maintain a connection. Sometimes it's best to drop when you are in car in a marginal connection area.
G87 M2 BSM On Order
      10-10-2023, 11:27 AM   #122
Rennology
Rennology's Avatar
Drives: IG @rennology
Looks like the update didn’t fix anything. Stay away from the charging pad!
https://wccftech.com/iphone-15-pro-o...17-0-3-update/
      10-10-2023, 01:23 PM   #123
Tejas1836
Tejas1836's Avatar
1044
iPhone tests show overheating problem (no relation to BMW charger issues) resolved
https://bgr.com/tech/thermal-test-sh...ix-is-working/
https://www.zdnet.com/article/iphone...er-ios-17-0-3/
      10-10-2023, 01:47 PM   #124
ramparts
ramparts's Avatar
1167
Drives: M40i
Those results are wrong.
The update was never to stop the phones getting hot ( they will always get hot unless apple clock down the CPU’s ), they were to stop the bad apps ( instagram etc ) causing a worse power failure that this test doesn’t show up.
This is also completely unrelated to the wireless charger issue , which apple/bmw are currently in active conversation about ( confirmed by BMW )
vded6.00
      10-10-2023, 05:01 PM   #125
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.95]
Maybe it is me but I have never used the wireless charger in any of my BMWs. So I have had zero problems with my iPhone 15.
      10-11-2023, 07:49 AM   #126
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
This is my approach also
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
DanG11345.50
      10-12-2023, 02:11 AM   #127
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
Same, the wireless chargers in these cars is god awful slow so I just plug into the usb of the car.
DanG11345.50
      10-12-2023, 12:57 PM   #128
G80indy
Save the Manuals
G80indy's Avatar
Almost makes me want to pull the fuse on this wireless charger.
Anyone know if that’s possible?
2023 G80 6MT, CCBs
      10-12-2023, 01:53 PM   #129
ramparts
ramparts's Avatar
1167
Drives: M40i
You can just unplug it underneath the pad. 3 small torx screws and you done in about 2 mins
      10-12-2023, 05:38 PM   #130
KevinC
your average JAMF
KevinC's Avatar
Drives: '21 M2 Comp, '19 Golf R
BMW should just come out with a MagSafe charger for iPhone owners, and everyone else can deal with this crappy Qi charging standard garbage.
nype163.50
      10-12-2023, 07:33 PM   #131
rons e92
60-130 Enthusiast
rons e92's Avatar
Drives: G87 M2
Does the digital key still work?
      10-13-2023, 05:33 AM   #132
Cruise'n
Cruise'n's Avatar
Drives: X5 M60i
2024 BMW  [0.00]
Have a Android Samsung Galaxy S23 Ultra and gets so hot can barely touch.
BMW bad design and should have airflow.
Pad cooling.
Vent grooves
Something.
But unlike Apple didn't blow up.
