10-04-2020, 10:10 AM | #67 |
Rep 313
honestly I'm not sure whats the maker of my unit or if I have the latest software.. this is a pic of the info on my unit .[IMG]undefined[/IMG]
10-04-2020, 07:15 PM | #69 |
Rep 313
So do u think my software is up to date ? Also just noticed my heads up display not functioning... Anyone have a issue with this during install ? Nothing shows up on my windshield and grayed out on my idrive screen ..I did have it gray out when I was coding last year ..maybe tomorrow I'll hook up on bimmercode and see if I can get it back on .. Thanks again
10-05-2020, 02:04 AM | #70 |
Rep 286
There are no newer versions available via the thread
https://f30.bimmerpost.com/forums/sh....php?t=1675929 Regarding hud maybe a wire was not reconnected during the install process? |
10-05-2020, 03:17 AM | #71 |
Rep 313
Not sure .I'm going to mess with it in the morning..but I did have the same issue when I was coding ..it just disappeared.and I wasn't coding anything to do with the HUD. It just grayed out and It deactivated itself , so I'm hoping it's something simple ..if not then I'll take car back to the installer.. another question.. when making calls ... The correct way to connect is thru both bluetooths? I seen that for me to make calls correctly looks like the unit has to b connected to the unit and the car .. dual connection.. if not I have to manually connect the unit to the car .. the last time it connected to both and I was about to make a call without jumping out of the unit ...and thanks again everyone for helping me out
10-05-2020, 03:20 AM | #73 | |
Rep 1,833
10-05-2020, 03:56 AM | #75 |
Rep 1,833
10-05-2020, 10:00 PM | #76 |
Rep 13
Where are you all installing the MMI box on your 6? I'm installing the kit now, but have run into an issue. The LVDS IN cable that connects to the MMI box (the factory cable that in the car) is too short to install the unit in the glove box. There is space however, between the glove box and the radio but not easy to secure. I may 3D print a bracket that mounts to the metal frame in that area. There is no space behind or under the factory radio/head unit, so you will need to find another place. I can post images if interested.
10-05-2020, 10:52 PM | #77 |
Rep 313
I got my installed by a local shop .he did have a concern about the placement.. not sure were he ended up placing it .. I do know the usb cable is running out of my glove box ..so I'm assuming is in the same spot u mentioned
10-06-2020, 06:08 AM | #79 |
Rep 3,071
I did the install myself and it will fit behind the radio down below, just a tigt fit. Also, a green mist connector must be relocated, easy to miss that. Also, program your radio button 8 to aux so you will be able to get sound if you switch audio between bmw annd the mmi.
10-08-2020, 02:59 AM | #80 |
Rep 286
Are u guys able to control any movement using the scroll wheel on the steering wheel? I've seen some videos where in certain apps like Spotify the scroll wheel will work to move through a playlist say. For me the scroll only works in the phone app.
10-08-2020, 04:56 AM | #81 |
Rep 1,833
Scroll wheel works across the entire interface for me. You have to nudge it between the left, center and right columns using the iDrive controller.
10-08-2020, 01:41 PM | #82 |
Rep 286
10-11-2020, 02:19 AM | #83 |
Rep 1,833
10-11-2020, 01:24 PM | #84 |
Rep 286
10-11-2020, 02:48 PM | #85 |
Rep 193
10-12-2020, 04:06 AM | #86 |
Rep 1,833
There is a setting. I will take a photo tomorrow.
10-14-2020, 07:18 PM | #87 |
Rep 313
Well today I took her to work as she's not my daily driver and if I would give the mmi kit a grade , it would b a F. couldn't connect at all to my Android auto .. then when I finnaly got fed up and changed to my oem bluetooth..my phone wouldn't connect for audio .I keep connecting to dual BTs is that correct ? Then when I reversed in to my parking spot I got rear camera malfunction.. coincidence ? I don't think so
10-14-2020, 08:23 PM | #88 | |
Rep 193
