10-06-2016, 08:18 AM | #45 |
Rep 21
Doughboy
Was wondering if I could confirm something you mentioned. You said you are using your old spacers off a 3 series 9X? I found a set of of H&R for 9x 3 series but the code is slightly different for the F12 M6. - 3 Series and E63/64 M6 (2075725) - F Series M3/M4, M5 and M6 (2075726) http://www.hrsprings.com/application...results/4/TRAK Could you let me know what brand of spacer you are using and if you happen to know why the difference in code? From what I can gather and by reading the code explanation on H&R's site, there is a slight angle on the hub with the new M4,M5 and M6 but can't be sure because it says the same angle on the 9x 3 series. Wonder why the code is different. Thank you. |
10-06-2016, 08:25 AM | #46 |
Rep 8,972
Hi,
Mine are Eibach spacers. I don't know about part numbers, I only know they fit perfectly on the hub spigot and the bolt holes line up. The outer diameter also perfectly matches the machined line / point on the hub face where it begins to chamfer inwards. The Eibach website shows the same parts for E9x and Fx see link and scroll down: http://www.eibachshop.co.uk/eibach-p...m#.V_ZRGeArLtU |
10-07-2016, 08:08 AM | #47 | |
Rep 21
03-30-2017, 09:05 AM | #48 |
Rep 739
I'm running Macht Schnell 12mm up front and 10mm in the rear. I'm also lowered on the KW HAS kit. I could have gone 12mm in the rears as well but i'm planning to go with wider 305 tires soon, and did not want to chance the wheels rubbing. Picks below are before and after.....
04-04-2017, 12:18 PM | #51 |
Rep 739
04-04-2017, 12:18 PM | #52 |
Rep 739
05-11-2022, 01:20 PM | #57 |
Rep 2
BMW 640xd springs & spacers
BMW 640xd
- wheels BMW style 374 (front 8,5Jx20 ET33 / rear 9Jx20 ET44 - tyres Hankook EVO 3 (front 245 35 20 / rear 275 30 20) - springs H&R 28947-4 - spacers H&R B3075726 |
05-11-2022, 05:56 PM | #59 |
Fueled by Recycled Dinosaurs!
650
Rep 1,181
Drives: F06 M6
looks great!
06-03-2022, 02:54 PM | #60 |
Rep 532
On my 2018 M6 GC both 275 front and 305 rear rub on stock 343M when lowered with a 10MM spacer. I have the Dinan coilovers set about .7" lower. The issue is the 9.5 / 10.5 widths bulge a little bit and the sidewalls are vertical. Wider wheels fix it as the tire leans over a little. I had to take my spacers out on the stock wheels to get rid of the bulk of the rubs. I was rubbing on the plastic liner and felt wheel well liner, not the fender. You could possibly heat and push and or trim those to be rub-less. I still rub in one small spot on the front without the spacer. YMMV.
