      02-20-2025, 11:52 PM   #23
Bmw_6
Drives: Bmw 6
Could you please let me know how did you install it and do you have any pictures how the screen mount looked like?
I cannot find a screen for 6 series, but I see screens for 5 series which should be the same, maybe just a mount is different. I see different screens with different mount holes at the bottom, not sure which one is correct. I would appreciate any information which screen to buy and how to install it.
Thanks
      02-26-2025, 09:32 PM   #24
Kolianovskyi
Drives: BMW 650i
Thanks
https://hifimaxnavi.com/products/12-...-f12-2010-2017
      03-03-2025, 11:41 PM   #25
Bmw_6
Drives: Bmw 6
Originally Posted by Kolianovskyi View Post
Hi Kolianovskyi,
I am looking for 14.9 inch screen. The link is for 12.3.
Thanks
      03-10-2025, 05:17 PM   #26
Kolianovskyi
Drives: BMW 650i
Hi Kolianovskyi,
Thanks
Ask them. They might have it as well.
      03-14-2025, 02:32 AM   #27
aibtus
Drives: 2017 BMW 640D Gran Coupe
Thumbs up Awesome 14.9" on 6 series
Originally Posted by iamvanja View Post
I did it!
Before and after
Can you share how you the installation, intsallation tips, dos and don'ts, etc. Did you connect the aftermarket cameras?
      03-19-2025, 01:15 AM   #28
iamvan
iamvan's Avatar
325
Drives: 23 840xi GC skyscraper/tartufo
For the screen installation, I remember following a YT video. It's not complex but a bit lengthy (give it at least an hour).
I did not install an aftermarket camera as I already had a 360 camera. Still, I remember that it took me many trials and errors to configure the access to the OEM camera system. Basically, to trigger the Android system to switch back to iDrive (and its camera view). I never figured out how to activate the camera system when pressing the camera button, only when switched to reverse. The iDrive's resolution also looked funky.
My biggest drawback was that the CarPlay resolution was not native to the screen. It is a blurry, upscaled mess. I tried connecting the Carkit dongle, and that refresh rate and resolution looked terrific! But then you lose the steering wheel controls and the iDrive controller. They had beta support at the time for physical controls, but Android and iDrive did not cooperate in successfully recording the presses in the learn mode. Perhaps it is better now!
I am a software engineer and also a bit of a perfectionist. The system is not for me. I played with it for several weeks and returned it. I was happy for years with an MMI box (press 3 to switch between iDrive and CarPlay). If I were craving a bigger screen now, I would highly highly recommend a Linux screen instead and wouldn’t bother with that Android crap.
      05-08-2025, 06:44 PM   #29
eugkim
Drives: X7 M60i, F12 M6, E63S
Originally Posted by Bavariane31 View Post
I wish I knew the above I made my purchase, but overall I am still happy with the 14.9" option. It added a lot more capability to my car. Maybe someday I'll upgrade again but for now I needed Carplay.
Are you still happy with this upgrade? You're the only one I can find that stuck with it.
      09-28-2025, 12:29 PM   #30
spit
Drives: BMW F15 x35i
Hello
Could you write more about this? Do you have any pictures you could add?
      09-28-2025, 04:00 PM   #31
Bavariane31
Drives: ‘03 530i, '16 640 GC
I don't regret purchasing the screen at all. Carplay is so much better than not having it. I just wished the resolution was a little bit sharper but it's not a deal breaker. I think it's worth it
I will mention that although the system switches to the camera most of the time, it messes up and doesn't during bootup and while linking to your phone. It's kind of annoying to swap back to the OEM software (by holding menu button on the iDrive) to see the reverse camera. Or you can hit the camera button.
So it's a little finicky. Probably best to stick with MMI box just for Carplay
      10-19-2025, 12:10 PM   #32
BMW5and7
BMW5and7's Avatar
2538
Drives: B8 Alpina; X7 M60; Mbenz GLS
The question I have for most of you here: Why not just buy a new headunit (OEM) that comes with ID6 and the wireless carplay and use that?
Am only here as am thinking of buying a fun weekend Alpina B6, so am reading about it.
      10-20-2025, 05:18 PM   #33
Bavariane31
That’s not a bad option but that’s why people have to buy things, review, and then others can read and decide what to do. A 15” screen is nicer for one. Android auto is a must for most people rather than carplay. Not any one option is going to be ideal to every person.
      03-14-2026, 01:47 PM   #34
nealsil
Drives: 2013 F13 M Sport
Hello all, i just installed a Linux screen in my CIC F13 and having the following issue: iDrive controller only functions when on the OEM interface. The only way i can use Linux/CarPlay is via touch. Would like to know if this is just inherent with all these aftermarket screens or maybe i have a problem unit?
Appreciate the feedback in advance. Thanks.
