05-02-2022, 07:53 PM | #23 |
Rep 642
There are two type of valve actuators. The pre-lci exhaust had a vacuum unit to open the valve. the later units are electronic actuators. The vacuum units just need vacuum applied to actuate. You can use a solenoid valve routed to a vacuum source. The later units require a controller. The positioning is done using Pulse Width Modulation to change the position of the valve.
F06 M6 Grand Coupe CP
05-03-2022, 12:40 PM | #24 | |
Customize Everything!
47
Rep 281
05-06-2022, 08:30 PM | #25 |
Rep 642
Not speaking from experience, but if you presently have electronic flaps, you should be able to use the electronic flaps of a different model with the same controller. The point is whether you are maintaining the same flap "motors" (vacuum or electronic). As far as the mufler swap, there were some discussion a while back on what saps are possible.
