12-07-2017, 02:40 PM | #23 |
Rep 149
Exactly , the Akrapovic exhaust has also flaps which are conected to vacum line just like the stock exhuast , when the Rpm goes above 4k ( i think ) the flaps open .
12-14-2017, 02:11 PM | #24 |
Rep 11,890
you got a picture of this baby installed yet? On my GC with MPE, the tips looks like it's angled down a bit. I've seen the angle on another car online before, but I've also seen it straighter on coupes and in the press photos.
Is it just an adjustment on the clamps for the tips or what?
12-15-2017, 11:03 AM | #25 | |
Rep 149
After i installed the exhaust i adjust my tips 3 or 4 time until they look the way i wanted them . Its also a matter of taste , just adjust them as you like , its very easy . |
12-15-2017, 12:15 PM | #26 |
Rep 11,890
thanks for the confirmation, so literally it's an adjustment I make on the clamps on the tips?
12-15-2017, 12:55 PM | #27 |
Rep 149
12-15-2017, 01:02 PM | #28 |
Rep 11,890
Also, I'm pretty sure I have the MPE (not that I'm accusing the dealer I bought the car from for lying that it was installed), but, in your photo of the exhaust laid out before install, it shows the Akrapovic M Performance wording stamped on the muffler canister.
On my canister, it is not stamped on it. However, it's stamped on my tips. Can you confirm the stamp on the canister actually doesn't show on the ground-face side of the canister? Regardless, I double check the canister style and it has the "3 ribs" that's the hallmark on all Akrapovic mufflers. And it by no way looks like this one (OEM CP exhaust): Is there any other details I should check to ensure it's the full Akra set of parts? Maybe the cats on the x-pipe having the "3 ribs" as well?
12-15-2017, 07:37 PM | #29 |
Rep 11,890
Did you do this flapper mod before you installed the Akra? Bc I was able to adjust my tips today, and I saw that the solenoid is way on the outer pipe and nestled against the corner of the bumper. I removed the outer tip and barely could put my hand up on it, let alone string a piece of wire and tie it. Almost seems like you need to unbolt the exhaust and let it hang down and do the mod, or remove the bumper. Any tips?
12-16-2017, 05:29 AM | #30 | |
Rep 149
If you mean the exhuast muffler , so yes it has the M performance logo and the akrapovic logo on it , and it is in the ground face-side . As in the picture : Is youre muffler empty ? Doesnt have any logo on it ? Last edited by aann; 12-16-2017 at 05:38 AM.. |
12-16-2017, 05:39 AM | #31 | |
Rep 149
It can be done while the exhuast is already installed but its harder . i remember i saw a video on youtube showing how to install it on bmw m5 f10 with stock exhaust using stainless hose clamps , its the same as the m6 oem exhuast . Last edited by aann; 12-16-2017 at 06:33 AM.. |
12-16-2017, 10:12 AM | #32 | |
Rep 11,890
I pulled up another photo, on the inner pipe near the solenoid, there should be an Akra pitch fork stamped into it too. http://f10.m5post.com/forums/showthread.php?t=914226
12-16-2017, 10:27 AM | #33 | |
Rep 11,890
Looks like if you put the car up, you don't even have to take the tips off.
12-17-2017, 01:54 AM | #34 |
Rep 11,890
Finally found the logo on the front side of the canister when doing the flapper mod!
06-21-2018, 12:48 PM | #36 |
Rep 238
Drives: BMW M6 comp
Garage List 2019 Aprilia RSV4 [0.00]
2015 Land Rover Ran ... [0.00] 2014 MV Agust Rival ... [0.00] 2009 KLR650 [0.00] 2016 Kawasaki KX450F [7.50] 2016 BMW S1000RR [8.50] 2014 BMW M6 [8.00] |
so.... i'm confused, does the competition package M6 have an akro muffer??
06-21-2018, 04:22 PM | #37 |
Rep 96
Drives: 2017 M6 coupe
Garage List 2012 Ford SVT Raptor [0.00]
2017 BMW M6 [0.00] 2107 BMW M4 [10.00] 2007 BMW 650i [0.00] 2008 MB E350 [0.00] 1999 Ford F350 Lariat [0.00] |
06-21-2018, 08:17 PM | #38 |
Rep 11,890
No, the two are not related. The akra is a dealer/port installed option
06-21-2018, 08:19 PM | #39 |
Rep 11,890
I've never experienced it
07-26-2018, 10:46 PM | #41 |
Rep 116
07-26-2018, 11:06 PM | #42 | |
Rep 11,890
Plus you don't need to have car on the lift to look. It'll be pretty obvious when you just stick your head under there. The competition exhaust is a flat aluminium canister with thin pipes. Akra has the wider pipes, titanium finish. This is the competition exhaust: Last edited by Flying Ace; 07-26-2018 at 11:15 PM.. |
07-29-2018, 01:27 PM | #44 |
Rep 149
