      12-09-2011, 11:57 PM   #199
Garduna
Garduna's Avatar
Drives: Sedona 1er|Yellow S3|NardoTTRS
Originally Posted by Rodzilla View Post
I like everything but that wing.
same here lol
      12-10-2011, 03:18 AM   #200
M3WC
What a huge mistake selling it as a Scion only in the US.
      12-10-2011, 06:52 AM   #201
GoingTooFast
Drives: fat cars are still boats
Location: compensating a fat car with horsepower is like giving an alcoholic cocaine to sober him up.
Originally Posted by Garduna View Post
same here lol
Where do you see the 'wing' on the production model?
      12-10-2011, 07:02 AM   #202
GoingTooFast
What about the Subaru? Won't it be sold in the US?! I'll be hard pressed to believe that...
Anyway, from an aesthetics perspective this is my order of preference:
Subaru> Scion > Toyota
      12-10-2011, 09:33 PM   #203
GoingTooFast
      12-11-2011, 12:08 AM   #204
M3WC
Talking about Toyota deciding to sell it with a Scion badge.
Huge mistake. That badge just kills the whole image of the car.
Subie has the upper hand in this.
      12-11-2011, 10:42 AM   #205
GoingTooFast
Easy...
      12-11-2011, 12:00 PM   #206
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
wow that guy is good xD
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      12-11-2011, 03:02 PM   #207
Year's_End
Year's_End's Avatar
Drives: 2020 Shelby GT350
Easy...
Very much like the 911 vids; it's all about the driver. He's got skills. The only way to wring this thing out into a prolonged drift would be a massive flick or a wet road.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      12-11-2011, 06:42 PM   #208
GoingTooFast
If you really need to believe that in order for your 'car world' and all those years of listening to Jeremy Clarkson's bs make some sense to you then go ahead. Fine by me.
But you have to ask yourself one simple question... why do the the most popular and successful 911s (available to the general public) were, are and always will be the all-wheel drive variants since the introduction of the 959 through the 964, 993 and all the models that followed?!
Let me help you to find the answer... BECAUSE THEY ARE SAFER TO DRIVE FAST!
Why?! Here's why...
Unbalanced car - engine behind the rear axle - 911:
Balanced car - 53:47 front-to-rear weight distribution - Toyobaru:
You you can't deny physics... but you can wave your hand to the crowd while you are driving a Toyobaru sideways - that's how balanced it is!
      12-11-2011, 10:50 PM   #209
Year's_End
Year's_End's Avatar
I really just made that comment to stoke some unnecessary conflict; I understand how weight distribution (and there's so much more to it than that) works man. I just like giving you a hard time.
      12-12-2011, 04:32 AM   #210
GoingTooFast
You are always welcome... I'm not the owner of truth you know!
      12-12-2011, 05:38 AM   #211
GoingTooFast
I don't think so... Subie will be more expensive than the Scion!
But if you are a badge snob you'll be better of buying a 911.
      12-12-2011, 09:00 AM   #212
Red Bread
Drives: Smog machines
You realize that a 50/50 weight balance is not ideal, right? A rearward bias is preferential, but most front engine cars can't achieve that, so just getting half of the weight on the back is considered beneficial. More weight in the back helps with traction, braking and can allow narrower front tires which can help greatly with drag coefficient and also allows smaller and lighter suspension components.
Ideally this current run of the BRZ/FRS/86 would have had a 45/55 or similar weight balance, allowing the future blown versions to not tip towards being nose heavy, which they likely will. It would also create a little more appeal to the "base" car in that it would retain slightly better handling and braking results than the blown cars.
      12-12-2011, 11:43 AM   #213
MediaArtist
There is No Substitute
MediaArtist's Avatar
Drives: Audi A6, 997 GT3 RS, E90 335i
QFT
'13 Audi A6
'07 Porsche GT3 RS
'08 BMW E90 335i
      12-12-2011, 11:52 AM   #214
BIMMERGUY91
Drives: 2014 335I M Sport
If only it would be turbo and awd. So sexy
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      12-12-2011, 12:26 PM   #215
GoingTooFast
You can look at the Cayman as having the perfect weight distribution for a racing car (and a low center of gravity due to the boxer engine).
The BIG advantage of having the engine in the middle of the car (between both front and rear axles) is initial turn-in. It's like the car would be perfectly able to rotate around an imaginary vertical axis passing through its center of gravity between the driver and passenger seats. However, due to the absence of the weight of the engine on the front wheels, once you start applying the throttle and the weight shifts to the rear, provided you don't have enough power to break the rear wheels traction, you will start to understeer. Thus, you loose some of the capacity to use the throttle to corner despite the fact that you are actually carrying more speed into the corner in virtue of the better turn-in.
So, another concept has to be accounted for - car's dynamic weight distribution. With Toyobaru's less than ideal weight distribution at 53/47 front to rear, the weight distribution shifts rearward under acceleration and becomes dead even at near-perfect 50/50 balance despite of the initial understeer due to a worse turn-in ability. This means you can get back on the throttle earlier allowing the car to accelerate with neutral weight distribution. The car's balance prowess lays on the right amount of rotation you get from the transition between braking and getting back on the gas. And, if things are done right you can essentially use the throttle to corner and the steering wheel to initially turn-in and opposite lock. That's the reason why precise, fast throttle response is so important and turbo-lag so detrimental.
That's the reason why drifting cars are front-engined rwd.
That's the difference between effectiveness and fun!
      12-12-2011, 12:46 PM   #216
GoingTooFast
Subaru Confirms Turbocharged Version of BRZ Engine
      12-12-2011, 01:11 PM   #217
Red Bread
And thankfully no stupid awd. This car really is shaping up to be quite interesting. Hopefully TRD/STI gets behind track support as effectively as Mazda has with the Spec Miata and things like a rear seat delete and rollbar become available quickly.
      12-12-2011, 01:15 PM   #218
Red Bread
I drive a Z3 M Coupe, the very definition of hoonage. I've also tracked a few Exiges/Elises that didn't have an over abundance of power or a capability to rotate under off-peak power very well, but they really didn't exhibit power-on understeer and were certainly capable of getting into the power earlier than any front engine car I've driven.
The one cautionary thing I have to say about the Lotii is that they had awful throttle response from a Toyota n/a engine, so hopefully the Toyota part of this engine is offset by the Subaru parts. I've tracked STi's too that had better throttle response than many modern drive by wire n/a engines.
      12-12-2011, 05:05 PM   #219
Red Bread
Originally Posted by CAPSGOD View Post
Drive by wire was the worst thing to happen to cars until electric steering was introduced.
Clutch delays deserve a spot in this list too.
      12-12-2011, 09:19 PM   #220
GoingTooFast
I drive a Z3 M Coupe, the very definition of hoonage. I've also tracked a few Exiges/Elises that didn't have an over abundance of power or a capability to rotate under off-peak power very well, but they really didn't exhibit power-on understeer and were certainly capable of getting into the power earlier than any front engine car I've driven..
Did the Exiges/Elises oversteer then?! Have you ever driven an equally lightweight front engine (rwd) car to really compare?!
There's nothing like the throttle response from a good NA engine... either driven by wire or otherwise.
If you drive a Z3 M Coupe you should know what I'm talking about...
