Forum for the entire range of BMW electric vehicles
BMW iX Forums BMW iX Discussions
      04-10-2024, 07:05 PM   #221
MAMOHT
Drives: BMW iX xDrive50
So, what coding app is the best for iX? Or they all do the same? I just checked and it looks like Bimmercode still does not support iX.
      04-11-2024, 04:24 AM   #222
zonwe51
Drives: g20 318i
My Car g20 Lci sport line is id8, I want to coding instrument panel to M Sport cluster but DKOMBI8 can't read in BU, How can I do? thanks~
      04-11-2024, 07:28 AM   #223
hugo_nz
hugo_nz's Avatar
3201
2022 BMW IX  [0.00]
Seriously…read the last few comments. It’s pretty clearly laid out.
      04-13-2024, 03:15 PM   #224
hugo_nz
hugo_nz's Avatar
3201
2022 BMW IX  [0.00]
You can’t. The files to do so aren’t available…simple as that.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic
      04-16-2024, 01:20 AM   #225
naty48
Drives: BMW IX 40
So currently its impossible to also enable TLA if Country restricted ?
Tried playing with HU_MGU module, edited anything TLA releated, and yet..
      04-16-2024, 06:43 AM   #226
roxxor
roxxor's Avatar
1164
Drives: 2024 iX50
Pretty sure that's correct. TLA was not something that (at least for the US) could be coded by "VO Coding", which is all that is available for newer models currently, including the iX. It required modifying a few individual codes in several different modules, which are no longer available for that "FDL" type of coding.
      04-24-2024, 12:43 AM   #227
naty48
Drives: BMW IX 40
I do have the older model (MGU21), iX 2022-12.
But yet no CAFD available other than HU_MGU and RAM (at least for the latest update).
But I am wondering, is it possible to pay someone to release those files?
      04-24-2024, 11:02 AM   #228
NomoTesla
Drives: BMW iX50
I'm considering getting BimmerUtility w/ dongle to turn on my anti-dazzle matrix lights. It doesn't look like the BU folks will be of much help in providing instructions how to do this. Does anyone know what setting needs to be changed where in BU to enable the anti-dazzle lights? I searched this thread and could not find the information, my apologies if it was already posted.
      04-24-2024, 11:45 AM   #229
javapro
Generalissimo
javapro's Avatar
Drives: 2024 iX xDrive50 Sport
Originally Posted by NomoTesla View Post
I'm considering getting BimmerUtility w/ dongle to turn on my matrix lights. It doesn't look like the BU folks will be of much help in providing instructions how to do this. Does anyone know what setting needs to be changed where in BU to enable the matrix lights? I searched this thread and could not find the information, my apologies if it was already posted.
Matrix lights? May be you meant to say anti-dazzle?
      04-24-2024, 12:11 PM   #230
NomoTesla
Drives: BMW iX50
Yes that
      04-24-2024, 02:34 PM   #231
hugo_nz
hugo_nz's Avatar
3201
2022 BMW IX  [0.00]
Almost 100% certain that BU won’t be the tool for this since the CAFD files are. Ot available and simple FA coding wouldn’t cut it. You likely need access to official tools like ISTA as well as signed files.
NomoTesla2378.00
      04-25-2024, 05:41 AM   #232
roxxor
roxxor's Avatar
1164
Drives: 2024 iX50
It would probably be easiest to get it done by BimmerTech in your use case NoMo. You could use E-Sys which comes with BU to do it and then get the signed files from someone online, but if you aren’t familiar with E-Sys I wouldn’t recommend it as it is possible to really screw something up. Better to just pay to let them do it for you.
      04-25-2024, 10:26 AM   #233
NomoTesla
Drives: BMW iX50
Thanks, that's probably what I will do. I thought BU was a user-friendly app that can allow us to change these things in an obvious and seamless way but apparently, that is not the case. At least not for me since this process wraps my brain up in knots.
      04-26-2024, 12:47 PM   #234
MikeElmendorf
Drives: 2022 BMW X5/2024 i5 M60
It was reported elsewhere that using the FA editor to remove 5AP and then getting an OTA update would enable the anti-dazzle. Is that not so?
      04-26-2024, 06:57 PM   #235
johninaustin
Drives: 2023 BMW iX xDrive50
I've read similar accounts. I just gave it a go. We'll see what happens when 3/2024 is released OTA (maybe in June?)
      04-26-2024, 07:31 PM   #236
roxxor
roxxor's Avatar
1164
Drives: 2024 iX50
I think that is only applicable if you are having it done at the dealer where they update every single module. As I understand it, OTAs sometimes do not include updates for all modules, which would mean that nothing would happen if the OTA didn’t include updates for the modules that control the Anti dazzle.
      04-27-2024, 05:38 AM   #237
MikeElmendorf
I had an update at the dealer to address other issues and it did not work. The OP who advised this path said he thought there was something different with how they update and relying on original VO versus OTA which would seemingly just write based on the VO in the car. Who knows?
      05-10-2024, 01:52 AM   #238
arkhi
Drives: 21 540i
Did you check to see if they reverted your VO? The dealer updates it using ISTA. Last I checked, ISTA just checks the VO from your car. Also, if an update doesn't apply to the module that you need for the VO to take effect, I don't think ISTA rewrites thr FDL codes on those.
      05-16-2024, 03:35 PM   #239
MikeElmendorf
Arkhi -
VO still showed no 5AP after the update.
      05-16-2024, 08:50 PM   #240
patrikr
Drives: 2023 760i, 2020 Model X LR
Yes, this works and I’ve done it on both our iX and the XM. It doesn’t seem to work as well as my previous fully coded 2020 X5 but it’s working pretty well.
      05-17-2024, 05:59 AM   #241
MikeElmendorf
Patrikr -
Was it only an OTA update that enabled it?
What’s different from the X5? I have it coded on our X5 and had it on my M550, which my M60 replaced. I miss it!
bmw
