      03-14-2021, 10:36 AM   #1
Hobasg20d
Drives: G20
Connected Drive while roaming?
My car is from the UK, but I am currently in a country without Connected Drive
How do I get the connection to be roaming enabled? For some reason it worked for week and stoped. Is there a way to get the eSIM connection on roaming?
      12-28-2021, 04:53 AM   #2
oliver07
Drives: BMW x1
Check that mobile data and data roaming are both activated. Check that your network provider has permission your device and plan for data roaming. Update the software on your device. Reboot your device. No, you can only activate eSIM when you are in your own country or from where you have got the sim. However, if you already have Jio eSIM activated on your smartphone with an active IR pack/ IR service you can use it in International Roaming.
