06-13-2020, 07:58 PM | #177 |
Rep 47
06-13-2020, 08:25 PM | #178 |
Rep 743
The zip file has a torrent link. The link works with an app or software to download the data from other users that have the actual files. Mac has torrent "software". I do everything on my android phone.
06-14-2020, 07:08 AM | #179 |
Rep 47
I see thanks, I guess that because the downloads on google drive worked for me then it's ok.
06-14-2020, 08:43 AM | #180 | |
Rep 269
Drives: ///M6 GC
1. Have you deleted the hidden files on the USB drive? 2. Do you have multiple USB ports in your car? Have you tried both? Links that might help you. - https://f30.bimmerpost.com/forums/sh...1438684&page=2 OSX show hidden files - https://www.youtube.com/watch?v=46_oe6UmXV0
06-14-2020, 09:00 AM | #181 | |
Rep 269
Drives: ///M6 GC
1. Edited 1st post & removed E-Sys Launcher. 2. FAT32 will not accept a file larger than 4GB. 3. You can buckle the driver side seatbelt. I always have a battery charger connected during map updates or coding. Don't recall the iDrive going to sleep.
06-14-2020, 09:52 AM | #182 | |
Rep 47
BadSeed158.00 |
06-15-2020, 04:08 PM | #183 |
ex deus machina
123
Rep 968
this is correct, it might have been exFAT32, I remember Windows 7 reported it as FAT32...maybe mixed this up
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
08-16-2020, 10:25 PM | #185 |
Rep 269
Drives: ///M6 GC
Links to 2 separate shares are in the 1st post. Download both of them.
>>> Generating FSC code for map updates - BMW_CIC_FSC_Generator.exe <<< Note:As of 08-16-20, 2021-1 missing from the Maps drop down menu. 2021-1 info missing in Lookup.xml Below is untested since I already have a lifetime code but you can try it out: Copy & paste to Lookup.xml file <SgbmId id="NAVD_000014B8_255_005_194" SWID_FscShort="00A8004D" name="Road Map NORTH AMERICA Next 2021-1" supplier="NTQ" sop="01.06.2020" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR="" NextNo="01474"> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> Note:As of 09-12-20, 2021-1 is available from the Maps drop down menu
08-20-2020, 11:25 AM | #187 |
Rep 44
The latest Premium maps are for 2020, as far as I know.
F12 650i M-Sport, F80 M3, G01 X3 M-Sport
08-20-2020, 12:51 PM | #188 |
Rep 181
08-21-2020, 05:32 PM | #189 |
Rep 187
Thank you yet again, Mr BadSeed for your assistance with the latest Navi update!!
08-22-2020, 08:38 AM | #191 | ||
Rep 269
Drives: ///M6 GC
Not yet. 2020-1 is the current
http://www.asavvyweb.com/windows/how...d-google-drive I made changes to the original instructions from the website. Step 1: Select the link with the file which you are trying to download. - when the web page loads, login with your Google account Step 2: Right click on file and select make a copy option. Step 3: Now navigate to your google drive, My Drive folder and locate the file you want to download Step 4: Right click on the file and click on download. Step 5: Now your download will be started without any problem. Step 6: When you finish downloading, delete the file from your My Drive folder then go to the trash & delete it forever. Repeat steps above for the 2nd map link.
08-25-2020, 05:02 PM | #192 |
Rep 1
NBT Next vs NBT EVO
Hello,
I just bought a used bmw, with NBTEVO system. I can see the 2021-1 maps uploaded but they are for version next. Would I be able to install NEXT maps on NBT_EVO idrive6. |
08-27-2020, 08:36 PM | #193 |
Rep 55
No, you will need the EVO map, as the Next one is for iDrive -4 in the initial NBT headunits.
08-29-2020, 01:33 PM | #194 | |
ex deus machina
123
Rep 968
08-30-2020, 06:23 PM | #195 |
Apprentice
84
Rep 492
This is fantastic, it worked perfectly. Thank you BadSeed!
One word of caution - the 2021-1 No longer fits on a 32GB drive. Despite variety of formatting options I kept getting an error that the drive was ~400MB too small. You need 64GB or bigger USB for this update. |
09-04-2020, 11:48 AM | #196 |
Rep 1
Thanks! I got this to work!
The 2021-1 info for Lookup.xml worked great, so thank you also for posting that Was missing a few files at the beginning, but once i figured out my issues I got everything working! |
09-04-2020, 10:38 PM | #197 |
Rep 59
2012 550i map update
can you tell me to how to update maps on 2012 f10. hu-cic
also interested in updating 2015 f83. hu-nbt i have never done this before but do have e-sys and ista plus if needed looks like the procedure is the first post in thread. for the procedure to generate fsc code, it says select nbt on the the tool. should nbt be selected even if car has the older cic unit (i see cic is an option in the key gen tool as well). not sure where to find the map files. Last edited by cheeber; 09-04-2020 at 11:34 PM.. |
09-06-2020, 09:38 AM | #198 | |||
Rep 269
Drives: ///M6 GC
Thanks for confirming
If you are generating the 1B file (CIC), the different setting in E-Sys is found here: http://bmw-icom-a2-wifi.blogspot.com...-fsc-code.html The rest of the instructions are in the 1st post. Step 10 is different for your F83 I think you can skip selecting CIC or NBT from the FSC generator. Once I select browse & select the DE.fsc file, it automatically selects NBT. Once you create a 1B.fsc file, it should select CIC automatically. I recommend generating a Lifetime code. For the CIC map, honestly I would just Google search it. Different members from different forums will post a link when its available.
