      06-13-2020, 07:58 PM   #177
F31MGUY
Drives: BMW F31 M
Originally Posted by rogerdiaz View Post
Thank you. Downloaded via torrent. Installed flawlessly on 2015 335i.
Sorry to ask but was is Torrent? I clicked on the attached file from previous post it downloads a 300Ko file and if I unzip it nothing happens. Maybe isn't compatible with MAC?
      06-13-2020, 08:25 PM   #178
rogerdiaz
Drives: 2015 335i
The zip file has a torrent link. The link works with an app or software to download the data from other users that have the actual files. Mac has torrent "software". I do everything on my android phone.
      06-14-2020, 07:08 AM   #179
F31MGUY
Drives: BMW F31 M
I see thanks, I guess that because the downloads on google drive worked for me then it's ok.
      06-14-2020, 08:43 AM   #180
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Hey first I thank you for all the hard work and the input it's really great. So I have followed all the steps and went through the discussions before I post this. But i'm sure I have misunderstood or missed something please help.
-Using a MAC I have downloaded both zip files part 1 and 2 with safari web browser, from there I unzipped them before adding to the formatted FAT32 USB 3.0 key.
-Cleared folders like mentioned and had exact same folders as in the picture
-Plugged USB KEY in my F31 while engine running and nothing pups up, also tried in navigation mode still nothing.
I tried several times and hopeless LOL.
I'm not familiar with both MAC (OSX) or the F31.
1. Have you deleted the hidden files on the USB drive?
2. Do you have multiple USB ports in your car? Have you tried both?
Links that might help you.
- https://f30.bimmerpost.com/forums/sh...1438684&page=2
OSX show hidden files - https://www.youtube.com/watch?v=46_oe6UmXV0
      06-14-2020, 09:00 AM   #181
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Originally Posted by CHECKERED View Post
A couple installation notes, trouble shooting, etc. this was done on an F15
For E-sys you don’t need it to be activated with a token, that’s only used for coding, to generate the FCS file I just used E-sys, NOT E-sys Launcher like the first post says, this worked for me.
You must use the provide software to format the drive as FAT32, exFAT32 does not work.
I tried to move the zip file in to the FAT32 formatted 128gb stick and had an error ‘file too large’ So had to unzip the files first and then move them over.
During the update the car would go into sleep mode and the update would stop, so I ran the engine for 45min-1hr for the update to complete,
I suspect you can drive around while its updating, but you just can’t use the navi
Thanks for the info.
1. Edited 1st post & removed E-Sys Launcher.
2. FAT32 will not accept a file larger than 4GB.
3. You can buckle the driver side seatbelt. I always have a battery charger connected during map updates or coding. Don't recall the iDrive going to sleep.
      06-14-2020, 09:52 AM   #182
F31MGUY
Drives: BMW F31 M
1. Have you deleted the hidden files on the USB drive? YES only by installing it in my windows laptop I was able to see those files and delete them manually. Basically I just bought a new USB key, had it formatted FAT32 first with my MAC, and second alternative my windows laptop from there I would download map files from my MAC to the key and either way my car wouldn't recognize the update. So I followed your suggestions for hidden files on MAC which I thank you again but there where no hidden files showing up. After all I plugged the USB key in my laptop again to see files and wow I was finally able to see those hidden files which my MAC created by duplicating the map files when I had them downloaded. I'm sure theres a way with MAC somehow to not run into this problem, seems to be originally from the MAC download to the USB key. Like a mentioned USB key is new and had it formatted several times LOL.
2. Do you have multiple USB ports in your car? NOT in my F31 Have you tried both?
Greatly appreciated BadSeed I just test drove my car and I can finally see the new roads now in our new neighbourhood instead of heading into a cornfield
BadSeed158.00
      06-15-2020, 04:08 PM   #183
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
this is correct, it might have been exFAT32, I remember Windows 7 reported it as FAT32...maybe mixed this up
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      07-24-2020, 10:08 PM   #184
ezaircon4jc
ezaircon4jc's Avatar
Drives: 2019 540i M Sport
THANK YOU!!! Google Docs was much easier than the Mega download!
BadSeed158.00
      08-16-2020, 10:25 PM   #185
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Links to 2 separate shares are in the 1st post. Download both of them.
>>> Generating FSC code for map updates - BMW_CIC_FSC_Generator.exe <<<
Note:As of 08-16-20, 2021-1 missing from the Maps drop down menu. 2021-1 info missing in Lookup.xml
Below is untested since I already have a lifetime code but you can try it out: Copy & paste to Lookup.xml file
<SgbmId id="NAVD_000014B8_255_005_194" SWID_FscShort="00A8004D" name="Road Map NORTH AMERICA Next 2021-1" supplier="NTQ" sop="01.06.2020" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR="" NextNo="01474">
<EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" />
<SwUpdate SwUpdateEntry=""/>
</SgbmId>
Note:As of 09-12-20, 2021-1 is available from the Maps drop down menu
      08-18-2020, 03:34 PM   #186
TomM6
TomM6's Avatar
Drives: F12 M6 individual
Is there a CIC Premium map 2021 link available?
Thanks
      08-20-2020, 11:25 AM   #187
dadaabmw
dadaabmw's Avatar
Drives: BMW 650i, BMW M3, BMW X3
Thanks
The latest Premium maps are for 2020, as far as I know.
F12 650i M-Sport, F80 M3, G01 X3 M-Sport
      08-20-2020, 12:51 PM   #188
TomM6
TomM6's Avatar
Thanks
Thanks
      08-21-2020, 05:32 PM   #189
AZ535i
AZ535i's Avatar
Drives: F10 535i
2013 BMW 535i  [0.00]
Thank you yet again, Mr BadSeed for your assistance with the latest Navi update!!
      08-21-2020, 06:55 PM   #190
ep3
Drives: 07 335i and 14 M6
Looks like the download limit exceeded. Any other way? I can create another torrent and host it for everyone.
      08-22-2020, 08:38 AM   #191
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Thanks
Not yet. 2020-1 is the current
No problem!
See if this works:
http://www.asavvyweb.com/windows/how...d-google-drive
I made changes to the original instructions from the website.
Step 1: Select the link with the file which you are trying to download.
- when the web page loads, login with your Google account
Step 2: Right click on file and select make a copy option.
Step 3: Now navigate to your google drive, My Drive folder and locate the file you want to download
Step 4: Right click on the file and click on download.
Step 5: Now your download will be started without any problem.
Step 6: When you finish downloading, delete the file from your My Drive folder then go to the trash & delete it forever.
Repeat steps above for the 2nd map link.
TomM673.00
ep322.50
CHECKERED122.50
      08-25-2020, 05:02 PM   #192
sunnyd732
Drives: 328D xdrive
Lightbulb NBT Next vs NBT EVO
Hello,
I just bought a used bmw, with NBTEVO system. I can see the 2021-1 maps uploaded but they are for version next. Would I be able to install NEXT maps on NBT_EVO idrive6.
      08-27-2020, 08:36 PM   #193
ep3
Originally Posted by sunnyd732 View Post
Hello,
No, you will need the EVO map, as the Next one is for iDrive -4 in the initial NBT headunits.
      08-29-2020, 01:33 PM   #194
CHECKERED
ex deus machina
CHECKERED's Avatar
works perfectly!
      08-30-2020, 06:23 PM   #195
walmark
Apprentice
walmark's Avatar
84
Drives: 550i F10 '15
This is fantastic, it worked perfectly. Thank you BadSeed!
One word of caution - the 2021-1 No longer fits on a 32GB drive. Despite variety of formatting options I kept getting an error that the drive was ~400MB too small. You need 64GB or bigger USB for this update.
      09-04-2020, 11:48 AM   #196
kamiiza
Drives: BMW X5 50i, Subaru WRX
Thanks! I got this to work!
The 2021-1 info for Lookup.xml worked great, so thank you also for posting that
Was missing a few files at the beginning, but once i figured out my issues I got everything working!
      09-04-2020, 10:38 PM   #197
cheeber
Drives: 12 550i, 15 m4
2012 550i map update
can you tell me to how to update maps on 2012 f10. hu-cic
also interested in updating 2015 f83. hu-nbt
i have never done this before but do have e-sys and ista plus if needed
looks like the procedure is the first post in thread.
for the procedure to generate fsc code, it says select nbt on the the tool. should nbt be selected even if car has the older cic unit (i see cic is an option in the key gen tool as well).
not sure where to find the map files.
      09-06-2020, 09:38 AM   #198
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
works perfectly!
Thanks for confirming
I used a 32GB Patriot RAGE XT drive.
Thanks for testing.
You need an ENET cable as well.
If you are generating the 1B file (CIC), the different setting in E-Sys is found here:
http://bmw-icom-a2-wifi.blogspot.com...-fsc-code.html
The rest of the instructions are in the 1st post.
Step 10 is different for your F83
I think you can skip selecting CIC or NBT from the FSC generator. Once I select browse & select the DE.fsc file, it automatically selects NBT.
Once you create a 1B.fsc file, it should select CIC automatically. I recommend generating a Lifetime code.
For the CIC map, honestly I would just Google search it. Different members from different forums will post a link when its available.
