      05-14-2020, 03:47 PM   #1
hirkaismyname
Drives: F06 CP GC
Sizing up Tires but Spacers are tricky
I'm going to be sizing up on my tires (275/305) from the OEM specs, but I'd like to also space out my stock 343M wheels.
The plan is go with IND's (Future Classic) 10/12mm spacers, but not sure which one should go on the front vs. rear given the size up on Tires.
Secondly, there all this jargon about three depth, and opened lugs/studs/nuts etc. that I'm getting confused on -- so need some help.
1. Do i need to purchase lug extensions (if so, what MM) to accommodate project Kix -- as in do I need a (https://ind-distribution.com/collect...conversion-kit) lug extension? If so how do I spec out the thread pitch and stud length.
2. These are the Lugs I'd like (https://ind-distribution.com/collect...ng-lug-nut-set) but not sure if the 54mm will work with the spacers (either 10/12mm).
and,
3. FC has these (https://ind-distribution.com/collect...onversion-80mm) for sale but Money2536 had some issues with implementing the Lugs because the future classic studs with the kit are too short? If so, will 80mm work?
Thanks for all the help.
Cheers and have an Excellent Day!
H
      05-14-2020, 05:49 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [0.00]
The safe thing is to ask IND before you place the order. If it turns out to be wrong you can resolve it easier. You will need roughly 1.25 times the diameter (~ 18mm) of thread engagement. Note: the M6 uses 14 x 1.25 mm thread.
F06 M6 Grand Coupe CP / 'E39 530I 5sp
Both Black/Black
The drive is the destination
      05-15-2020, 12:46 AM   #3
brad850csi
Drives: 16 F13 M6 Comp
I'm running 10mm wider at the front and 20mm wider at the rear, so the top corner of my tyres will be 5mm and 10mm further out than yours. I'm effectively running a 6mm spacer at the front and a 1mm at the rear.
So if you got 11mm at the front and 11mm at the rear the top corner of your tyres would be in the same place as my car. I think that 10mm or 12mm will be around right
https://www.6post.com/forums/showthr...ht=325%2F30r20
      05-15-2020, 07:29 AM   #4
HeyKC
Drives: BMW M6 CP
So are you wanting to convert to lugs? My spacers came with extended studs.
I would say try the 12 in the rear first then if you have to switch them around its pretty simple.
      05-15-2020, 09:48 PM   #5
Whipple
Whipple's Avatar
120
Here some pics ,Stock suspension ,stock 433 wheels 265/35/20 in front, Rear is 305/30/20 ,Future classic spacers 10mm front 10 mm rear zero rubbing didn't go 12mm in rear to leave more space for wider tires.when I take wheels off all the lug bolts are compatible,no different sizes to deal with
      05-18-2020, 09:56 AM   #6
AaronLG
Drives: None
So you think with the 10mm spacer a 315 would fit ok?
Also I'd like to see more pics of the wheels. Been thinking of getting my 433 done in black also.
      05-18-2020, 03:41 PM   #7
Havy
V8 addicted
Havy's Avatar
Germany
243
Drives: M6 Gran Coupé
I like the idea of having 305 in the rear. I have also 10 mm in front and back.
      05-18-2020, 06:43 PM   #8
Whipple
Whipple's Avatar
120
Im not sure if 315s will fit you might have to take rear spacers off for that ,Im running michelin 4s now but to get a little more traction Michelin CUP2s will be a little better
      05-20-2020, 09:44 PM   #9
Whipple
Whipple's Avatar
120
These wheel look really nice in gloss black, the pics really dont do them justice how concave they really are,I get tons of compliments on them!
Im gonna take more pics on the car at different angles soon I will post then for you.
      05-29-2020, 08:26 AM   #10
AaronLG
Drives: None
They look killer! Really thinking they will work well with my Moonstone.
      05-29-2020, 11:11 PM   #11
Whipple
Whipple's Avatar
120
Oh yeah on Moonstone they will look sick!The gloss black will make that color pop
