07-13-2019, 11:17 AM | #1 |
Rep 1,493
NBT Upgrade
So I was reading to upgrade my head unit and to my understanding I believe I have a NBT Evo (build date 10/14). I have the touch pad feature too. Is it a simple screen swap and just coding?
07-14-2019, 02:26 AM | #2 |
Rep 1,825
What do you want to upgrade to? Evo is as far as you can go at the moment since the new iDrive system uses new connectors, gateways etc...
07-14-2019, 04:00 PM | #3 |
Rep 1,493
07-15-2019, 03:49 AM | #4 |
Rep 1,825
If you are referring to the new iDrive 7 then it's not going to be possible for quite a while, if at all.
Given how extensive the hardware changes are as well as the new protocols in use etc. a retrofit would require quite a complex adapter to work around all of that. If I were a betting man I'd put my money on there never being a retrofit for iDrive 7 into unsupported models. |
07-15-2019, 05:27 PM | #5 | |
Rep 1,493
07-15-2019, 07:38 PM | #6 |
Rep 1,825
07-16-2019, 09:16 AM | #8 |
Rep 7,475
maybe this will help...if you have ID4...you can probably upgrade o ID5 or ID6:
thebmw1632.00 |
07-16-2019, 12:39 PM | #9 |
Rep 1,493
07-16-2019, 02:06 PM | #10 |
Rep 1,825
It will be at minimum a new computer. You may be able to use the existing Display if you get a voltage converter. Depending on your specific equipment you may also need to change the sound system amp and antennas. Install should be mostly plug and play.
I can recommend getting in touch with Bimmer Retrofit...I bought my kit from them and their support is top notch. Even though the retrofit process has been covered extensively the 6-series seems to have little idiosyncrasies that can complicate the install. If you are not confident in or experienced at retrofits, wire splicing and reading technical diagrams then I would recommend having an installer do it. |
07-16-2019, 10:32 PM | #11 | |
Rep 1,493
Thanks man. Truly appreciate the info. I’ll reach out them. |
07-17-2019, 05:34 AM | #13 |
Rep 1,493
07-18-2019, 05:04 PM | #14 |
Rep 7,475
My 2013 f06 can play a DVD...I inserted one a few months ago just to see if it would...and it did. The movie (assuming that's what you are wanting to watch) won't play unless you are parked...unless you code "movie while driving" on.
07-18-2019, 10:50 PM | #15 |
Rep 2,906
Well dang, now I have to try this, and now I may be a fan of coding even though I never have been before.
07-19-2019, 08:50 AM | #16 | |
Rep 7,475
Who sits in a car for over an hour watching a movie in a parked car on a little screen? And you'll probably drain the battery if the engine isn't running or started periodically...which wastes gas. I don't get it...so apparently this feature wasn't targeted towards someone like me. Coding the DVD in motion...now that makes sense...but still kind of dangerous if the driver is in the car alone and is trying to watch a movie while negotiating traffic.
07-22-2019, 07:51 PM | #17 | |
Rep 1,698
Video entertainment should be kept to the back seats!
NorthCountryGuy1711.00 |
