05-29-2019, 10:35 AM | #1 |
Rep 71
2014 M6 Gran Coupe - Issues?
Good afternoon.
Im looking at M6 Gran Coupe, possibly a 2014 or 2015.... since most of these are our of factory warranty are there "issues" cropping up on these cars or items a potential buyer should keep in mind or look for? Thanks for the feedback !
1997 HMC4 Hummer H1
2003 KSC2 Hummer H1 1969 Jaguar XKE 2014 M6 GC |
05-29-2019, 11:52 AM | #3 |
Rep 432
I have '14 M6GC still under factory warranty and I just took it in to the dealership yesterday for a "minor rear diff seal leak". This was found when I got the car last year and had a PPI done. It's about a $1,100 job, but 100% covered under warranty. Other than that no issues.
05-29-2019, 12:13 PM | #4 |
Rep 628
32K miles '14 GC CP with no problems. Has been out of warranty for a year and a half. No mods except for exhaust flap remote.
F06 M6 Grand Coupe CP
05-29-2019, 02:16 PM | #5 |
KrazyKorean
33
Rep 242
My buddy that has been a master tech at BMW for over 10 years has told me that our cars are pretty solid cars. Of course there is small annoying things that can happen and are common issues like most cars but can be easily fixed.
But you need to understand these cars were like $130k + MSRP, so parts, even doing yourself are pretty pricey, so put that in consideration. Even do your own oil change will cost you about $120 bucks with OEM oil and filter. Dealership will want like 4 times that. So I would factor all that in as well. All that being said, I have a 2014 with 60k miles. I only needed to replace plugs and 1 coil but generally plugs should be replaced at that time. I got the infamous Drive train malfunction, but it was either the #6 coil or plugs to just replaced all plugs and coil, which was only like $200 bucks in parts |
Flying Ace4984.50 |
05-29-2019, 02:21 PM | #6 |
Rep 84
I posted this in another thread asking a similar question,
I ended up with a 2015 M6 GC fully optioned with the competition package. 27k miles. I haven’t owned it long enough to say anything about the engine or transmission. But I have come across a few posts where engines have been replaced. The transmission seems to be fine, but if you are planning on increasing power there is always an increase in risk associated with the engine and transmission. But from my own personal experience I am in the middle of having the A/C evaporator replaced at the dealer which is a $3700 repair at retail cost. I’ve already spent $370 for a drain and fill to try and identify if there was a leak and the dealership couldn’t find it anywhere. So their next assumption is the evaporator which is buried in the dash. Luckily BMW USA agreed to cover 80 percent of the cost of the repair. The overall situation has been an absolute pain to deal with. So my advice is to find something with a warranty and/or get a really thorough pre purchase inspection along with reviewing the maintenance history on the vehicle.
2015 M6 GC competition - fabworx downpipes/aFe dry filters/bootmod3 stage 2
05-30-2019, 12:33 AM | #8 |
Rep 29
2014 M6 GC. All stock. Bought used @ 27k, now has 43k.
Replaced battery & communications module after SOS warning light came on. Replaced leaking turbo coolant inlet, rear transmission seal, & oil pan gasket. Replaced leaking turbo crossover pipe, turbo coolant return lines, turbo coolant heater jacket, leaking oil return cover, air intake tubes, crankcase vent hose. Covered under CPO/goodwill, but otherwise would probably be $5k+ in repairs. |
06-03-2019, 02:18 AM | #9 | |
Rep 92
06-03-2019, 03:29 AM | #10 | ||
Rep 746
06-03-2019, 03:48 AM | #11 |
Rep 51
06-03-2019, 07:11 AM | #12 |
Rep 92
Did you have to take the car to a dealer to update the car?
06-03-2019, 08:08 AM | #13 |
Rep 746
Now we are talking... so no need for new equipment? Just a recode?
06-03-2019, 08:10 AM | #14 | |
Rep 51
06-03-2019, 08:32 AM | #15 | |
Rep 51
I don't think you can fix the sos malfunction warning by coding. Dealer told me they want to first try fixing that issue by giving me the update. If the update doesn't take care of the issue, they were going to change module or something. In my case, the update took care of it. |
06-07-2019, 08:34 AM | #16 |
Rep 2
Hi, I just got 2014 M6 GC w/ 32k miles last month and one issue.
B&O audio system goes into endless on and off cycle after cold start for about 5 mins then it goes back to being normal.. will have to check it out with the dealer.. other than above, no issue thus far |
06-07-2019, 08:57 AM | #17 |
Rep 56
I have the car for a year and at 52k, I had to replace a battery and the rear axles leak a little bit. Other than that, it has been rock solid. So far the M6 GC has been the most well built car I have had. No rattle and materials are high quality. Best car I have owned in term of issues and quality ( I own all Japanese cars before this BMW) .
06-17-2019, 12:01 AM | #18 | |
Rep 611
06-23-2019, 11:24 AM | #19 |
Rep 2
well took the car to dealer and they re encoded the audio amp to fix the issue. 1 week later, had to goto dealer again for another issu, system was showing all the malfuntion (bakes, seat belt, drivettain.. etc). SA telling me they need to replace the whole cluster.. cost is 3k.. going thru 3rd party warranty
12-14-2019, 12:14 PM | #21 |
Rep 11,891
More days points over on the m5 section of the forum. Basically same car
12-14-2019, 07:55 PM | #22 |
Rep 333
'14 GC Comp Pack, 45k miles. Had a full PPI done by BMW and Blackstone Lab oil analysis, no issues at all besides a slightly rattly steering wheel vibration motor (common issue).
