Go Back   6Post.com | BMW 6-Series Forum > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models)
      01-08-2024, 07:55 PM   #1
sub7m19
Drives: BMW X5 E53
How to know when Valves are closed
Hi, I am looking to time-cert my spark plug hole that has degraded threads since my spark plug won't tighten. Moreover, is there anyway to know when the intake and exhaust valves are fully closed? I heard that getting chips in there or in the cylinder can be really bad. Any tips would be greatly appreciated!
      01-09-2024, 07:43 AM   #2
grannyknot
grannyknot's Avatar
1001
Drives: 2008 Z4M coupe
You have to remove the cylinder head to do that repair properly.
If you drilled it out and installed the Time-sert with the head on and started the engine the chips would most likely be blown out the exhaust passage and not the intake.
The real danger is the chips getting caught in the compression ring, and scratching the cylinder wall, that would result in lower compression on that cylinder.
Take the head off.
2008 E86 M coupe
DrFerry6748.00
chris7197541.00
      01-09-2024, 09:35 AM   #3
Chihuahua
Chihuahua's Avatar
4378
Drives: E30 329iS, E65 Alpina B7
Take the head off.
+1, absolutely should take the head off to do any kind of machining, which in a sense is what you're doing. You'd be surprised how little debris it takes to completely destroy an engine.
      01-09-2024, 09:40 AM   #4
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
Take the head off.
Can't you just vacuum out the shavings from the spark plug hole? Or have the intake valves open and snake the vacuum down the cylinder from there while you drill the spark plug hole.
      01-09-2024, 10:22 AM   #5
4JawChuck
Drives: 2013 128i SE
Have you tried to just clean the threads with a tap first?
You can coat the tap with heavy grease to catch any shavings from entering the cylinder.
An insert repair indicates completely stripped/missing thread's which is unlikely, usually they are just damaged and need restoration with a tap.
A helicoil or timesert repair should be done with the head off, too many possibilities of not catching all the debris.
grannyknot1000.50
      01-09-2024, 10:23 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Take the head off.
100% agree!!!
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      01-09-2024, 01:50 PM   #7
grannyknot
grannyknot's Avatar
1001
That would be a pretty small vacuum hose, but I guess you could and if you very through you would probably get most of the chips.
I think it is just as likely that you would miss some and then you run the risk of scratching the cylinder walls.
If it were a beater I would probably take that chance but if it were my baby, no way. Or as 4JawChuck mentions a tap with some heavy grease on it, that is a great idea.
2008 E86 M coupe
      01-09-2024, 02:34 PM   #8
sub7m19
Drives: BMW X5 E53
I don't think I have the experience to take the whole head out. I saw a couple videos on youtube and they did the insert on the block without having to take it off. They just super greased up the tap and vacummed it afterwards. Im pretty sure the threads are gone as it wont even hold the spark plug in place. If i remember correctly the spark plug blew up in that hole bc oil was leaking into it for a while hence why I ended up taking everything apart and redoing the valve cover gaskets
