09-08-2019, 01:28 PM | #1 |
Rep 73
Retrofiting BlindSpot Warning Mirrors
Hey guys,
I have 2016 BMW M6 Gran Coupe with Active Blind Spot monitoring but the yellow symbol is on the pillar not the actual mirror, is it possible to switch to a mirror one? |
09-08-2019, 02:50 PM | #2 |
Rep 8,108
Before you can even get to the rewiring of electrical harnesses (which is probably not that difficult for electrical gurus) so that the data that gets sent to the existing warning triangle...gets moved over to the wiring harness that would send the data to the mirrior's harness...WHERE do you get the mirror fabricated to have the warning light embedded that will also fit your BMW's mirror assembly as well as still dim and be heated?
Unless you have the money, time, and expertise (or the people that do)...how bad do you really need to have that warning moved the approx 5"-6" from its current location out to the mirror? Is there a gain for the money/time/effort to do this? Is there even a BMW model that has the blind spot warning in the mirror that could possibly provide a donor mirror? Just poking around in the BMW TIS...I ran across this info about the Blind Spot (aka Lane Change) warning:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-08-2019 at 03:32 PM.. |
09-08-2019, 08:35 PM | #3 | |
Rep 73
So the new BMW 5 series has it embedded into the mirror, i was wondering if it would be possible to take that since its a BMW OEM part and install it to my 2016 M6 and code it |
Tags |
blind spot |
