      11-05-2020, 08:58 PM   #1
asih7262
Drives: F30 335
Rim fitment F06
Looking at a set of rims with tires to put on my 2014 M6 Gran Coupe and need to know if they will fit correctly. I need to know if they will fit flush and if they'll fit without rubbing
I will be lowering 1" with KW HAS
& will use a 5mm spacer in rear
Wheel / Tire specs:
Bolt Pattern: 5x112
Front Wheel Size: 21" x 10
Rear Wheel Size: 21" x 11
Front Offset: +22mm
Rear Offset: +26mm
Bore Size: 66
Tires: Michelin Pilot Sport 4S / Michelin Pilot Super Sports
Front Tire Size: 275/30Z/R21
Rear Tire Size: 295/30Z/R21
      11-06-2020, 09:12 AM   #2
Just asking...but are you aware that the specs for the wheels you gave appear to be geared toward the new generation G chassis BMWs. Some of the specs for the wheels are not compatible with the F body 6 series and you would need hub-centric wheel spacers (front & rear) to at least handle the differences in the wheel specs you mention vs what would fit your F06 6 series:
  • Bolt Pattern:
    • F06: 5x120
    • -vs-: 5x112
  • Bore Size:
    • F06: 72.56mm
    • -vs-: 66mm
HeyKC101.50
      11-07-2020, 09:35 AM   #3
LJohnson32
LJohnson32's Avatar
Drives: 2016 BMW M6 Gran Coupe
Here is a helpful tool for these types of use cases:
https://www.willtheyfit.com/
      11-07-2020, 10:50 AM   #4
asih7262
Drives: F30 335
  • Bolt Pattern:
    • F06: 5x120
    • -vs-: 5x112
  • Bore Size:
    • F06: 72.56mm
    • -vs-: 66mm
Yes i realized this after i messaged the seller , I didn't even notice the bolt pattern was 5x112 bc they were listed for an M5 .. i wonder why BMW changed theyre bolt pattern
