      08-15-2022, 04:30 PM   #1
G30M
G30M's Avatar
3948
Drives: BMW M550i; Kia EV6 GT
iDrive 7 Bluetooth audio not working
sorry i post in the general thread for more response in case someone has a great solution
so when going on a 4 hr drive the bluetooth audio decided it will not give sound
"no source available" was the iDrive 7 message
under Music - No device connected. click connect device
under Connected Device - Samsung S22 - Phone, Message, Music
in my phone Bluetooth - BMW - Phone, Message Audio
Play music in phone - no sound in phone, sound being transmitted via bluetooth
BMW - "No source"
Check uncheck everything i can find on the iDrive, connect disconnect the phone multiple times on iDrive in every menu i can find, also the same on the Phone.
Delete Bluetooth Connection on Phone, new Pairing
Nothing, same no audio despite iDrive saying it is connected.
Cannot restart iDrive as driving.
So i just connected Android Auto and upon arrival drained all my battery but at least I had music
ANy ideas?
Please and thank you
edit - i think when i get home I'll try reboot iDrive using my OBD-Bimmercode, not sure if that will fix it
      08-15-2022, 04:31 PM   #2
G30M
G30M's Avatar
3948
PS i can't use wireless charging on this phone as the phone heats up to frying egg temperature and it doesn't seem to gain charge only negative delta battery % so i don't want to fry my phone's battery (Li Ion hates heat)
It's a Samsung Galaxy S22 Ultra (basically a Note 22)
      08-17-2022, 09:51 PM   #3
Burr001
Burr001's Avatar
Philippines
3403
Drives: 2022 X3 M40i
2022 BMW x3 m40i  [10.00]
BMW - "No source"
ANy ideas?
Hold down Volume button till system resets while the car is on.
      08-18-2022, 01:13 AM   #4
G30M
G30M's Avatar
3948
it won't reset no matter how long i press. i'm away now, will plug in the OBD and reset with bimmercode when i get home
fingers crossed ...
      08-18-2022, 09:54 PM   #5
G30M
G30M's Avatar
3948
well this morning it decided to play audio
i have no idea
      08-20-2022, 04:03 PM   #6
dlong82
Drives: M3CX
It takes at least 20 seconds before pressing and holding the center of the manual volume control will cause a reset. Screen will go black. Keep holding until you hear about 3 clicks (I assume relays) from under the dash). Took my g80 in for break in service. Got home and realized I had no audio. Reset fixed it.
      09-23-2022, 11:51 AM   #7
Izyrela
Drives: '18 340i M Performance Edition
Any updates on this fix? I just starting having the same problem with my 340i. Phone is connected to Bluetooth but audio won't connect. I even tried factory reseting idrive but it didn't work
      09-30-2022, 12:55 PM   #8
JuniorTech
Drives: F30 340i Msport & G05 X5 40i
chek fault memory in car
