01-19-2018, 05:57 PM | #1 |
Rep 56
Door open window retract
As expected, the windows on all four doors retract about 1/4 inch when the doors are opened. On other cars I have owned, the windows would drop when the handle was partially pulled, but before the latch mechanism engages. In other words, the window would drop before the door physically moved. The 640 does not do this - the windows drop about the same time the door moves. Is this unique to my car and possibly a problem, or normal?
Pondering the important stuff on a Friday night.... Thanks in advance. |
01-21-2018, 09:22 AM | #2 | |
Rep 84
Window retract when the handle is completely pulled, this mean the door is already in a opened position. If you watch closely you can see the window has enough space to open without the need to go down, it serves only for when you close the door, to make sure the rubber seal the window correctly without pinch. Last edited by Aliendex; 01-21-2018 at 09:28 AM.. |
01-22-2018, 12:32 PM | #3 |
Rep 11,891
I don't see a problem with it. My M6 does exactly what you described too. The key purpose is fulfilled which is to create a tight seal on the window, so the manner shouldn't matter.
If anything on the "other cars", it's actually a bit imperfect for the windows to come down so early IMO. Near simultaneous movement with the door is preferred.
01-22-2018, 05:27 PM | #4 |
Rep 56
Thank you both for the replies. I had a 996 a few years back, on which the window retracted just as the door handle was partially pulled (but before the door moved). The door handle switches on that car were weak and required replacement (a big PIA), which is why I noticed the way the 640 doors work. Looks like they function as designed - so that's fine.
Thanks again. |
