01-18-2021, 04:17 PM | #1 |
Rep 209
Tire setup advice
Hey guys,
Looking for some advice on what size tires I should get for my F13 M6. I want to have most aggressive setup for my wheels. Wheels: Rohana RFX5 F: 20x10 ET +25 R: 20x11 ET +35 KW HAS Suspension. Thank you ! |
01-18-2021, 07:30 PM | #3 |
Rep 200
First,
use this to see how the new rims will change your stance ; for example will the offsets work etc and how much compared to stock are your rims poking out/caving in, then you can use the second link to calculate max tire size 1) https://www.willtheyfit.com/index.ph...9-5&offset2=20 2) https://www.wheel-size.com/calc/ Hopefully you can find a set up which fits without having any rubbing issues |
HeyKC101.50 |
01-19-2021, 12:28 PM | #4 | |
Rep 187
I don't know enough to understand how much you can push it but, when I start looking for new rears I think I am going to go with PS4S in 315s. Last edited by HeyKC; 01-19-2021 at 12:37 PM.. |
FinalRenegade208.00 |
01-19-2021, 12:32 PM | #5 |
Rep 2,352
The stock wheel offset is 19mm so you'll need ~15-20mm spacers at the rear for a start.
I'd go 275/35r20 and 305/30r20 or 315/30r20
