03-05-2023, 06:18 PM | #1 |
Rep 8
Power cut out help needed
NEED HELP! Did 2 pulls before completely warm and pulled hard no drop. Then when full warm 3rd at 5 k rpm felt like I hit the redline( that's what it feels like). I did this pull 3 times and got the drive train power loss warning, which went away after turn off or turn on the back to normal driving. The car drive normal just can go wot. Any help is greatly appreciated 2015 m6 only mode is bms intakes. No tune
03-17-2023, 03:33 AM | #3 |
Rep 311
Easiest thing to do is check the MAF Sensor connectors and make sure they are connected and seated all the way… with engine heat and half a dozen years in these things get loose specially if you have had them unplugged and Re plugged… they have a little clip lock so be careful not to break that.
If all is good reset the error codes if you have you have the mobile and and dongle otherwise that would be the next step and then see if you get the engine light again… This plug will cause idle and powertrain malfunction along with boost emergency shutoff errors… Then move onto plugs and coils… easy DIY… Tip: spark plugs must be seated perfectly and tightened to spec, coils are shitty and ensure they locking clip is fully seated so the coil is fully engaged and has no loss of pressure… from my experience some coils can be difficult or faulty on the locking plastic mechanism. |
03-17-2023, 08:30 AM | #4 |
Rep 662
Have you had any engine work recently performed? I had this same issue and couldn’t figure it out. Ended up being the DME connections were loose. Need to make sure they are snapped well into the grommet holes and there’s no wiggling.
Under WOT, they become disconnected just enough to cut power. After you let up, they fall back into a good spot, restoring power. Hope this helps. |
Msparta316.00 TinCanSailor645.50 |
03-17-2023, 08:40 PM | #5 | |
Rep 311
Glad to see your tip since I too have had long term troubleshoot issues to only discover a halfway decent connection that needed better snug connection… |
