11-05-2020, 08:58 PM | #1 |
Rep 2
Rim fitment F06
Looking at a set of rims with tires to put on my 2014 M6 Gran Coupe and need to know if they will fit correctly. I need to know if they will fit flush and if they'll fit without rubbing
I will be lowering 1" with KW HAS & will use a 5mm spacer in rear Wheel / Tire specs: Bolt Pattern: 5x112 Front Wheel Size: 21" x 10 Rear Wheel Size: 21" x 11 Front Offset: +22mm Rear Offset: +26mm Bore Size: 66 Tires: Michelin Pilot Sport 4S / Michelin Pilot Super Sports Front Tire Size: 275/30Z/R21 Rear Tire Size: 295/30Z/R21 |
11-06-2020, 09:12 AM | #2 |
Rep 8,094
Just asking...but are you aware that the specs for the wheels you gave appear to be geared toward the new generation G chassis BMWs. Some of the specs for the wheels are not compatible with the F body 6 series and you would need hub-centric wheel spacers (front & rear) to at least handle the differences in the wheel specs you mention vs what would fit your F06 6 series:
HeyKC101.50 |
11-07-2020, 09:35 AM | #3 |
Rep 361
11-07-2020, 10:50 AM | #4 | |
Rep 2
Yes i realized this after i messaged the seller , I didn't even notice the bolt pattern was 5x112 bc they were listed for an M5 .. i wonder why BMW changed theyre bolt pattern |
