| Yesterday, 08:18 AM | #1 |
![]() 41
Rep 286
new to me m440i, want to make it best it can be
So i picked up a 2024 m440i with 44k on it. It looks great, but it has the spider web looking swirls in the clear, not bad, but they are there. The front has a bit of road debris thats nicked the paint. Its not so bad that its obvious unless you get down and inspect. The hood has a couple tiny dots that have been hit with touch up but not great, as you can tell it.
I know its really too late for ppf unless you go and get all that fixed, but i prefer to spend money on performance mods, so expensive paint repairs are prob not gonna happen. I thought about doing ppf but read that it all needs to be repaired and painted first. How many of you are not running any sort of PPF? How does your vehicle look? Any tips or tricks to keep it looking good for those who go non ppf. Also, for light clear coat spider web rings, what would be the best process for that? Otherwise the paint looks great really. Oh, and some parts of the car have like tiny copperish colored parts kind of stuck in the clear. I tried clay, and it would get some but it would take a lot of work. Is there a product that gets rid of all of that? |
| Yesterday, 09:46 PM | #2 |
![]() ![]() ![]() 556
Rep 549
Take the car to a detailer for a proper paint correction. It's going to be much easier to maintain everything with a professional start. They will buff and polish everything they can out for you. After this step is where you want to pull the trigger on PPF since the prep is done. PPF is the only way to protect against road debris. You can do what's called a "highway" package if you don't want to go full car.
Also DO NOT take the car through one of the drive-through washes. Washing and wiping the car incorrectly is what has caused the "spider web" swirls in the 1st place..GL |
| Yesterday, 10:55 PM | #3 | ||||
![]() 202
Rep 170
You can put PPF on a car with some rock chips and imperfections. It will guard against additional imperfections. Though if there's notable paint damage (read: more than some small rock chips), then the compromised paint could potentially be pulled off down the line when you need to remove the PPF. If the paint is factory and generally in good shape, you won't have to worry about that. The touched up areas can be wet sanded to take down the touch up paint and blend it with the surrounding material so it's much less noticeable. Quote:
Good washing and drying habits are a must.
Those are the basics, but there are plenty of YouTube videos and other resources that cover good washing methods. Never ever take the car to a brushed carwash. Don't let a dealer or oil change place do a "courtesy wash" for you. Don't go to a car wash where they hand dry the car as you leave. Don't let people lean up against the car. For some reason people love to lean up against cars, with the rivets on their jeans gouging the paint. And if possible, remind people not to beat their shoes up against the side skirts in an attempt to remove dirt from them before entering the car. The floor mats can be vacuumed. For some reason, some people are in the habit of beating their shoes into the side skirts like this. Quote:
Generally for a full correction you'd decon the paint (chemical decon / iron remover, clay bar), then compound it to remove the imperfections, then polish it to make it glossy and remove any artifacts that the compound leaves behind. Then apply protection to keep the paint looking good (panel wipe or alcohol mix wipe down after polishing to remove polishing oils). Quote:
Iron removers generally turn color when they contact iron particles, and you'll see a purple or brown bleed coming from the iron particles. It's possible it's another type of contamination. But generally you see the following:
When using high or low pH products, always rinse very well, and ideally follow up with a pH neutral soap to neutralize the harsh stuff. Last edited by fiveightandten; Yesterday at 11:02 PM.. |
| Bookmarks |
