Originally Posted by gmd2003
The problem is the Aventador has a legit 700 hp engine , aggressive gearing , and WAYYYYYYY better aero all while weighing in at 37xx pounds . There are multiple instrumented tests of the Aventador running 10.x and 133-34 real trap speed not GPS. It is in the 5.8-6 flat range 100-200km/hr too. Its a real deal super car. I have SS DP's , Gruppe M intake and full Akrapovic exhaust with a piggyback on top of my CP ECU. I'd bet my car is within 30 hp of any PP variant based on my own acc numbers as I have hit 129mph GPS in the 1/4 in non ideal +1300 density altitude conditions and run a mid 7 60-130 mph. FYI you can not extrapolate a 60-130 from a 100-200km/hr (62-124), as they are quite different. Every mph over 120 takes considerably longer, and the difference between the two numbers can be over a second .
I did not extrapolate 60-130 from a 100-200km/h did I? "I said subject to"..... I just wanted to give you an example to see how fast a 660 HP car can catch that numbers and for the same car with %10-15 more power we expect much better number (I don't say %10-15 more)
