The stock wheels are 31mm offset front and 19mm rear.
I'm running 25mm front and 18mm rear with 285/35r20 and 325/30r20 tires, so my setup is:
Front: 6mm further out from the offset, then 5mm further out from the 10mm wider tyre - so I'm 1mm further out than you
Rear: 1mm further out from the offset, then 10mm further out from the 20mm wider tyre - so I'm 1mm further out than you as well.
As such I think you'll be fine and I think that my offsets sit really well on the car - mine is at stock height though.
