Originally Posted by JC04
2.4 bar is 34-35 psi is correct. Don't run 3.1 bar, which is 44 psi. You'll wear down the middle of the tires and ruin them.
Depends on tire. I run my PSS in front at 36 and my rear R888 at 34. These are cold pressures. You will have the wobble till they warm up. Also, these tires are not meant for cold seasons so it will take longer for the wobble to go away if it ever really does on a short commute. These cars are extremely delicate steering as well. Any little changes in tire pressure, season, the car sitting for a long time creating temporary flat spots; all will affect feeling through the steering.
Maybe get the tire/wheels balanced then play with the pressure. That's really the easiest place to start trouble shooting and most likely the wobble will go away.
