View Single Post
      11-29-2020, 09:03 PM   #10
Whipple
Whipple's Avatar
175
Originally Posted by GiftyM6 View Post
Thanks a lot ! Do you suggest 10 or 12 mm
I went with 10mm in all 4 corners,im running stock 265 front tires and 305 in the rear the fitment is pretty damn good no rubbing,I might even try a 315 r888 in the rear with the 10mm spacers might just make it
A lot of guys run 10 front 12 rear but at that point you can only run stock width tire is a 295,If you want to run a 305 it might rub
