Originally Posted by NDAzone
Hi all, I was thinking of getting a second set of wheels for my summer tires since I have Pirelli run-flat snow tires on the stock 20's. I figure if I keep swapping between winter and summer tires, the tires will get trashed. Am I wrong?
Anyway, the M6 wheels I am looking at getting are the style 433 OEM wheels. They are also 20" but wider with a different offset. They are 9.5 inches wide with a 31 mm offset (I'd run a square setup with the same rim size all around.).
My current wheels are 8.5 inches with a 33 mm offset in front and 9 inches with a 44 mm offset in back.
Will the M6 front wheels fit my car on all corners? I also have 12 mm spacers up front and 15 mm spacers out back. I suppose I would have to remove them for the new wheels.
Thanks for any input.
Nope M6 wheels won't fit. M5 wheels do thou.
Really. I'm surprised. Thank you.
Front will stick out past fender considerably
