View Single Post
      01-09-2020, 01:48 PM   #10
dyefremov
Originally Posted by brad850csi View Post
This was about the biggest list of FF15 sizes I could find. https://www.ravspec.com/shop/hre-ff15
I'd be tempted to go with 20x10 33mm with no spacer as the top edge of the tyre will still be 3mm further out with a 275/35r20 than the stock 31mm offset wheels with a 265/35r20 tyre. However the 20x10" 40mm option would give you the ability to run a 10, 12, 15mm bolt on spacer to get the fitment where you want it to be.
Based on my rear fitment, you could do the same sort of thing with the rear and go with a bunch of different spacer options. Honestly I'd probably say buy a pair of 10mm and 15mm with those offsets and try each spacer size at the front and the rear and see how you think things look best.
There are a few threads about with people running 10mm to 15mm spacers on stock wheels which might make you think you could go with slightly larger spacers than 10mm with those offsets. Just do a search for spacer or spacers and you should find plenty of pics.
Thanks for the suggestions! Appreciate your input.
