Hi all, I was thinking of getting a second set of wheels for my summer tires since I have Pirelli run-flat snow tires on the stock 20's. I figure if I keep swapping between winter and summer tires, the tires will get trashed. Am I wrong?
Anyway, the M6 wheels I am looking at getting are the style 433 OEM wheels. They are also 20" but wider with a different offset. They are 9.5 inches wide with a 31 mm offset (I'd run a square setup with the same rim size all around.).
My current wheels are 8.5 inches with a 33 mm offset in front and 9 inches with a 44 mm offset in back.
Will the M6 front wheels fit my car on all corners? I also have 12 mm spacers up front and 15 mm spacers out back. I suppose I would have to remove them for the new wheels.
Thanks for any input.
Chairman of the board.
2016 Alpina B6
