Originally Posted by KennyFSU
Thanks guys, loving the car so far and surprisingly the MPG has been identical.
This is the funny part.
People assume that bigger engine = worse fuel economy.
In reality, it comes down to driving style. Under heavy load, bigger naturally aspirated motors actually have the same or BETTER fuel economy than smaller, turbocharged motors.
So why are smaller turbocharged motors rated higher on EPA fuel economy numbers? Because those numbers assume everyone drives like a grandma. Yes, if you drive like a grandma, then smaller turbocharged motors will have better fuel economy numbers than a large V8. But you don't buy a sports coupe to drive like a grandma.
Manufacturers are well aware that their high powered sporty coupes/sedans will be typically driven in a spirited manner. But because of blanket government policies, they're incentivized to hit a target fuel economy figure. In the case of the EPA, out of the series of tests they conduct, the most aggressive test assumes a 0-60mph time equivalent of 7 seconds. Now with cars in this class easy in the 3-4 second mark, 0-60 in 7 isn't exactly "spirited".
