      01-25-2013, 06:45 AM   #1
barclay
Drives: 2024 540ix
Very squeaky, loud brakes at low speeds
I am in Chicago and it has been pretty cold for the past week. Dealer tells me it is quite common right now and there is nothing they can do...it is a result of the cold weather. Anyone else?
      01-25-2013, 03:41 PM   #2
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Yes I have the same thing under 15mph coming to a stop from my front left brake. Its annoying.
My Thread:
      01-26-2013, 07:29 AM   #3
jettie1767
Drives: '23 BMW i7 xdrive60
Same for me....embarrassing!
      01-28-2013, 09:23 AM   #4
jump
Drives: 2015 M5 - Alpine White
2013 BMW M5  [0.00]
I'm having the same issue in Chicago with my 2013 M5. A couple people in the M5 forum suggested making some hard stops and it seemed to help a bit.
*Retired 2013 M5 - Black Sapphire*
Meisterschaft Exhaust
      01-28-2013, 03:56 PM   #5
OC Dealman
OC Dealman's Avatar
Drives: 15' M6 Vert - Comp Package
Yes, same thing is happening with mine. As others stated, it is very embarressing. I asked dealer and was told that because of the heavy amount of brake dust and the size of the brakes, there is nothing that can be done except to brake later!???? Between the squeaks from the seats and the brakes, and rattles and crackling from the speakers, I have to say that these little issues are starting to cause me to sour on the car a bit.
      01-30-2013, 08:24 AM   #6
jettie1767
I just got my car back from dealer. Their answer was that this is due to me feathering the brakes which causes them to heat up and therefore squeal. In other words, they asked me to mash the brakes harder or just not brake at all...LOL!
      01-30-2013, 12:31 PM   #7
PrecisionP
PrecisionP's Avatar
Drives: ATPC's
Bat out of hell driving recommended even in the driveway. Duly noted.
      02-10-2013, 07:18 PM   #8
jettie1767
Car going back to dealer tomorrow after I gave them bad ratings on the service follow-up survey.
      02-11-2013, 06:57 AM   #9
barclay
Drives: 2024 540ix
They should come to you with a loaner instead of you having to waste your time going to them...my noise went away when it warmed a bit as they said.
      02-11-2013, 06:04 PM   #10
jettie1767
I had to discuss to the shop foreman all the problems I wanted fixed. As for the brakes, they said all they could do is disassemble and clean them.
      02-14-2013, 07:55 PM   #11
fitmaster
fitmaster's Avatar
Drives: 2013 M6 Convert / 2015 M3
I noticed when you use a spray tire or wheel cleaner, the residue gets on the rotors and will cause some squeaking until it wears off. Can go on for weeks. Not sure if this the answer but it happened to me and I had the rotors cleaned and it never happened again.
      02-17-2013, 08:15 PM   #12
jettie1767
They cleaned the brakes last Tuesday and today is just the second day driving the car. Squealing is back! This is absolutely driving me nuts! Now I need to send in the car for the third time....sigh....
      02-17-2013, 10:16 PM   #13
Ak3249
Ak3249's Avatar
13
Drives: BMW F12 M6 Cab
I have squealing from the same brake disk and in the same situation.
      02-18-2013, 10:44 PM   #14
Hunter5179
Hunter5179's Avatar
Just stop hard or abruptly from 40-60mph and it will go away. Its brake dust build up from feathering the brakes or being to gentle.
My Thread:
      02-20-2013, 04:07 PM   #15
jettie1767
I got the same response from the dealer again today. They said BMW engineers told them that it is normal for high performance brakes to squeal and for me to brake harder. So, I told the dealer, if this is your response, you just lost a customer. As soon as I said that, I get a call from the dealer telling me they will escalate and to have new brakes ordered but it has to be approved by BMW USA. I told them, do what you have to do because I will not take 'it is normal' for an answer. I said, if this is normal, you should document it in the owner's manual and also add it to the Monroney sticker so that an unsuspecting buyer will know beforehand to expect squealing brakes before plunking down $126k for a car.
A few minutes later, dealer calls again and tells me BMW USA approved the request to order a new set of brakes. Total cost is about $5k. If they know how to treat their customers right, $5k is chump change.
      02-20-2013, 04:11 PM   #16
jettie1767
I've tried that but it doesn't last long before it squeals again.
Seriously, how many folks actually brake abruptly all the time just to prevent this car from squealing? It wouldn't take long before someone actually rear ends you for braking abruptly at a red light.
      02-21-2013, 01:07 AM   #17
Hunter5179
Hunter5179's Avatar
I know. I hear ya. It sucks and its super annoying especially having someone in the car..they think your car is busted or something. Good deal on getting the new brakes but if they are the same they put on the assembly line won't it just happen again like on all of ours?? I'm going by the dealer and they said they will use some sort of grease to calm the brake dust down. We'll see how that goes.
My Thread:
      02-21-2013, 08:10 AM   #18
jettie1767
Yes, it most likely will. But, I'm hoping I will get a few months of quiet at least. I asked them to put brake paste but they don't seem to want to listen.
      02-21-2013, 09:22 AM   #19
PrecisionP
PrecisionP's Avatar
Drives: ATPC's
So did they say the squealing is from the brake pads/assembly or the contact with the rotors?
      02-21-2013, 12:28 PM   #20
I Bleed BMW Viscous
I Bleed BMW Viscous's Avatar
Drives: M6 F12 soon...
Unhappy
Any updates on all the folks who have said their Brakes were Squealing? I'm just about ready to purchase an M6 Cab, but with all the talk about Structural rigidity and now the brakes, I might have to go check out the Merc, or XKR...
03 M5/ 02 540/ 01 M5/ 00 X5 4.4/ 99 M3/ 95 M3
"If you do what you've always done, you'll get what you've always gotten." Tony Robbins
      02-22-2013, 07:33 PM   #21
TiAgMC
Drives: BMWs
so a bunch of owners all saying they have the same problem and being told it is normal by BMW, perhaps that means it is normal if many people are experiencing the same thing?
      03-01-2013, 01:45 PM   #22
Hunter5179
Hunter5179's Avatar
The car is awesome.. if you feather the brakes a lot you will build up brake dust and you will get that noise... just step on them a little bit more and your good.. Structural rigidity?? please fill me in on what you've heard because from my experience its Solid.
My Thread:
