Reply
      01-16-2013, 07:29 PM   #23
neversummer78
neversummer78's Avatar
Drives: 2013 650i GC
Originally Posted by nwills View Post
Did you put a screw through the exhaust pipe to block the flap open? Wouldn't that make a hole in the exhaust?
I tried blocking the rubber pipe but the flaps remained closed!
From the technical drawing, the actuator is right on the exhaust. If you can unhook it and zip tie the link/arm that control the flap, then that should do the trick. However, I think the flap does more than just the sound but also control the back pressure. If you keep it open all the time the torque might be affected a bit. Probably not too bad since it got a lot to spare to begin with. I will try to look into it next weekend unless you get it working and wanna share some photos before that.
00 323ci blk, 03 S2000 sil, 04 525i sil, 05 X5 beige, 07 328i sil, 08 C350 gray, 10 MCS Conv gray, 10 MCS red, 12 ML350 BT sil, 13 650i GC blue, 12 E350 Wagon 4Matic blk
neversummer78 is offline   United_States
      01-17-2013, 03:40 AM   #24
objectdyed
Drives: F13
I tanke some pictures later! you dont have to make a shole in the exhaust...
objectdyed is offline   Reply With Quote
      01-17-2013, 04:38 AM   #25
andreo
BMW Enthusiast
andreo's Avatar
Drives: Citrin Black 650i Coupé (F13)
Yes please show us.
andreo is offline   Macao
      01-17-2013, 12:50 PM   #26
neversummer78
      01-26-2013, 01:00 PM   #27
shap650
Drives: 2009 x5 4.8i vermillion red
PROBABLY resignator deleted.
shap650 is offline   Reply With Quote
      01-26-2013, 04:32 PM   #28
neversummer78
Hi nwills, check out photos I uploaded. That is how I keep flaps open. It sounds like a proper V8 now.
      01-27-2013, 03:07 AM   #29
andreo
BMW Enthusiast
andreo's Avatar
Looks easy enough. Will try it out this weekend. Let you know how it goes.
      01-27-2013, 07:14 AM   #30
neversummer78
      01-27-2013, 11:42 AM   #31
nwills
Drives: 2012 535xi
Thanks for the pics!
I'll give it a try!!
nwills is offline   Reply With Quote
      01-27-2013, 08:38 PM   #32
neversummer78
Enjoy!
      02-03-2013, 06:29 PM   #33
andreo
BMW Enthusiast
andreo's Avatar
The zip tie method worked perfectly. Thanks to Summer78. The small hole in the mounting arm made it possible.
      02-03-2013, 07:45 PM   #34
EmMHoLLa
Drives: BMW 650i
In extreme heat wouldn't the zip tie Melt?..
EmMHoLLa is offline   Reply With Quote
      02-03-2013, 08:11 PM   #35
andreo
BMW Enthusiast
andreo's Avatar
That's what I was concerned with too. It does not come in direct contact with the exhaust but I suppose heat may still transfer via the control arm. Time will tell.
      02-03-2013, 11:31 PM   #36
neversummer78
Welcome!
      02-03-2013, 11:35 PM   #37
neversummer78
I was thinking about that too, but that is what I happen to have lying around. If it breaks, then I will replace it with metal tie.
      02-04-2013, 12:41 AM   #38
andreo
BMW Enthusiast
andreo's Avatar
How is yours holding up so far? Care to share a picture?
      02-04-2013, 12:54 AM   #39
neversummer78
I don't have the pic, but it is still there.
      02-23-2013, 09:42 PM   #40
microchips
Drives: BMW 640i Gran Coupe
which do you guys prefer on 640i GC, eisenmann race exhaust or meisterchaft GTC (EV controlled) ?
microchips is offline   Reply With Quote
      02-24-2013, 12:26 AM   #41
neversummer78
I prefer Meisterchaft b/c I like EV control feature. Eisenmann is great too. It depends on your taste, so it is best to check them out in person before committing to one.
      02-25-2013, 11:09 AM   #42
mlai
Drives: 650GC/Vellfire/E93 M3 Cab
I also did the mod tonight! I did not have the m sport exhaust but still sounded very good. However, I noticed a very tiny bit of droning at idle after the mod.....
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
mlai is offline   Hong Kong
      02-25-2013, 12:17 PM   #43
neversummer78
I hear the droning at idle too but no problem so far.
      02-25-2013, 08:42 PM   #44
mlai
Neversummer78 and Andreo,
My 650i GC also felt a tad more responsive with the mod. My friend who test drove the car last night also mentioned the same and asked what I did (I didn't tell him the mod).
Did you guys feel your 650i a bit more eager to go and more responsive after the mod? Or am I and my friend just hallucinating........
Reply
Forum Jump
