Reply
      11-26-2012, 02:46 AM   #1
neversummer78
neversummer78's Avatar
Drives: 2013 650i GC
650i GC - Exhaust note - Cold Start
Update!
I used zip tie and keep flaps on both sides open. It is sounding much better at low speed.
00 323ci blk, 03 S2000 sil, 04 525i sil, 05 X5 beige, 07 328i sil, 08 C350 gray, 10 MCS Conv gray, 10 MCS red, 12 ML350 BT sil, 13 650i GC blue, 12 E350 Wagon 4Matic blk
neversummer78 is offline   United_States
      11-27-2012, 12:15 AM   #2
nwills
Drives: 2012 535xi
Love that sound!! I wish it always sounded like that...when in sport mode and hard on the throttle you can get some real music from that exhaust but the valves remain close most of the time making it tame!
Wish there was a way to keep the valves open!
nwills is offline   Reply With Quote
      11-27-2012, 12:25 AM   #3
neversummer78
Yeap, somebody gotta make a mod for that. I can't hear much in the car while driving until I lower the windows. I wonder how X-Pipe works on this car. I used X-Pipe once in C350 and it was very sweet. It cost roughly $100 including installation and tax. That would be an awesome reasonable mod.
      11-27-2012, 12:31 AM   #4
nwills
Drives: 2012 535xi
Here's an option for our car!! albeit a little pricey
This is a 650i....I'm sure it would be the same on the GC
      11-27-2012, 05:13 AM   #5
neversummer78
Yeap, I checked the price 2 weeks ago, and I have to look the other way. They have optional wireless remote valve flaps control which is very neat. With EV, it is basically $4000.00 without installation.
Also, it isn't CARB approved, so cannot be used in CA.
"products are not EPA or CARB approved and are intended for off-road/track use only"
      11-27-2012, 11:45 AM   #6
djsaad1
Drives: range rover
Are there any aftermarket exhausts for the 650 that will allow you to keep the original exhaust tips?
djsaad1 is online now   Reply With Quote
      11-27-2012, 12:57 PM   #7
neversummer78
I have not come across any which is why I am thinking about X-Pipe mod. X-Pipe should allow for more aggressive note yet retain the OEM look. I didn't get a chance to lift and look at the underside yet, but there should be a spot for X-Pipe.
      11-27-2012, 08:23 PM   #8
kbryce
I have to return some video tapes
kbryce's Avatar
Drives: e92 335i 6mt
that is badass as hell
13 Black Sapphire e92 335i - 6mt - Coral Red - M-Sport - No mods for 1,200 miles!
10 Le Mans Blue e92 335i - Retired
09 Monaco Blue e92 328i xdrive - Retired
07 Sparkling Graphite e92 328xi - Retired
kbryce is offline   United_States
      11-30-2012, 02:25 AM   #9
neversummer78
I found YouTube for F10 550i with X-Pipe and stock mufflers. It sounds pretty good.
      12-10-2012, 02:08 AM   #10
neversummer78
Found a new video with X-Pipe for F12/F13 but also with Meisterschaft exhaust.
      12-11-2012, 11:10 PM   #11
neversummer78
Found X-Pipe by Supersprint for 650i but not GC.
http://www.supersprintna.com/product...arch_model/286
      12-11-2012, 11:39 PM   #12
neversummer78
I just checked with RealOEM and center muffler, part number 18307646960, seems to be connected to front muffler and rear exhaust system with simple clamps. May be I will visit local exhaust shop to see if they can build something to replace center muffler, so I can put on stock later if I don't like the sound.
      01-11-2013, 12:34 AM   #13
neversummer78
What did this guy do to his car? Why does it sound so aggressive?
      01-14-2013, 07:19 PM   #14
nwills
Drives: 2012 535xi
+1...checked the youtube link and there is no mention of what was done!?
      01-15-2013, 01:02 AM   #15
neversummer78
X-Pipe may be?
      01-15-2013, 01:08 PM   #16
objectdyed
Drives: F13
got the regular M exhaust with "opened flaps"
objectdyed is offline   Reply With Quote
      01-15-2013, 01:15 PM   #17
neversummer78
wow! I gotta try that
      01-16-2013, 02:45 AM   #18
nwills
Drives: 2012 535xi
I thought the flaps only open at a certain speed or rpm? Did you do anything to open the flaps???
I'm also very confused of people referring to the M exhaust? I have the 650i with the M sport pack and I couldn't see any mention of the M exhaust in the list of things included. Is there in fact an M exhaust?
      01-16-2013, 02:54 AM   #19
nwills
Drives: 2012 535xi
I googled and realized that some do a mod to keep the flaps open.
Not sure if this is what was done to the car that was posted above from Germany?
I need to figure this out...I want it done right away!!!
      01-16-2013, 06:04 AM   #20
objectdyed
Drives: F13
yes! for a more agressive sound the open flaps are definitive a must have ;-)
normally the flaps opens at a certain rpm!
its very easy to open the flaps, you can just lock/fix them with a little screw. thats it. tooks 5 minutes!
your can also do a different mod if you cut off the hose wich opens the flaps: http://www.e90post.com/forums/attach...1&d=1183338204
but I dont tested it!
but for a better and more agressive sound, the open flaps are a must have
      01-16-2013, 01:53 PM   #21
nwills
Drives: 2012 535xi
Did you put a screw through the exhaust pipe to block the flap open? Wouldn't that make a hole in the exhaust?
I tried blocking the rubber pipe but the flaps remained closed!
      01-16-2013, 02:05 PM   #22
djsaad1
Drives: range rover
Do you know what speed or rpm the flaps open? There might be a way to code it to a lower rpm. Knowing the rpm value would make it easier to find though.
Reply
Forum Jump
