Reply
      11-25-2012, 07:48 PM   #1
nwills
Drives: 2012 535xi
Back fire (popping noise) on deceleration
I've noticed on my 650i Gran Coupe while in sport mode that when I come to a stop I get some "pops" coming from the exhaust...back firing. It's pretty much doing it 75% of the time.
It sometimes only gives me a gurgle with slight popping or an all out relatively loud pop!
Is this normal...anyone else experience this?
nwills is offline
      11-26-2012, 02:41 AM   #2
neversummer78
neversummer78's Avatar
Drives: 2013 650i GC
I got that too. I thought I ran over manhole cover a few times. I guess it is normal, since I am not the only one.
00 323ci blk, 03 S2000 sil, 04 525i sil, 05 X5 beige, 07 328i sil, 08 C350 gray, 10 MCS Conv gray, 10 MCS red, 12 ML350 BT sil, 13 650i GC blue, 12 E350 Wagon 4Matic blk
neversummer78 is offline   United_States
      11-26-2012, 09:42 AM   #3
SAMLAMBO
Drives: 2010 BMW 730Li
Perfectly normal
2012 BMW 640i (AC Schnitzer Package)
2011 Mercedes E250
2007 Ford Mondeo
SAMLAMBO is offline   Reply With Quote
      11-26-2012, 11:47 AM   #4
ctenidae
Drives: 2012 650i Coupe- Manual
Perfectly normal, and bad ass, when used correctly
I love that little backpressure burble.
ctenidae is offline   United_States
      11-27-2012, 12:12 AM   #5
nwills
Drives: 2012 535xi
Used correctly!? Any tips you care to share!? :-)
nwills is offline   Reply With Quote
      11-27-2012, 09:37 AM   #6
SAMLAMBO
Put it into sports mode and use the paddles to downshift when you need to downshift
2011 Mercedes E250
2007 Ford Mondeo
      11-27-2012, 10:43 AM   #7
coldfusion1998
Drives: BMW 650x1 GC M-Sport
Smile Popping Noise
I have it too, love the sound although it scares my wife!
coldfusion1998 is offline   Reply With Quote
      11-27-2012, 01:24 PM   #8
ctenidae
SAMLAMBO's downshift suggestion works if you have the automatic. I have a stick, so really, all I have to do is wrap it up a little bit and take my foot off the gas- usually goes "burble burble BLAP burble burble THUD burble burble"
Wrap it way up to red line and let off the gas, and you get the funky turbo whine as the wastegate opens, followed by the rumble and backfire.
I presume in an auto it's tougher, as you have to overide the transmission's clutch disconnect somehow.
      11-29-2012, 04:45 AM   #9
AC Schnitzer UK
Drives: over 200mph
It's unburnt fuel from the engine burning in the exhaust. Perfectly normal. On some engines the fuel injectors are shut off completely on the overrun but this tends to make the ride jerkier. If you were permitted to run an open exhaust from the turbo onwards you'd see flames at night...
AC Schnitzer UK is offline   United Kingdom
Reply
Forum Jump
