      04-03-2018, 02:12 PM   #1
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
Auto close window up issue
Hi All!
Today, I noticed after driving for a bit with the windows down (all 4), the drivers rear window would "bounce" if I did the one touch up. What I mean is, trying to get it to auto close, it goes about 3/4, then bounces back down to open. I have to manually hold it to close it. Is this something that is programmable, or an issue?
I will be taking it to the dealer for a right rear rattle noise, so this may be added, just wondering if I can change this setting.
Thanks!
      04-03-2018, 03:17 PM   #2
upstate650
upstate650's Avatar
2020 BMW M340xi  [0.00]
Originally Posted by mgmarsh39 View Post
Hi All!
Thanks!
You will see this periodically, but not regularly. I see it maybe once every 3 or 4 months. When it happens, push and hold the button down while the window goes all the way down. Continue to hold for a couple seconds after it is all the way down. No pull and hold while the window goes all the way up. Continue to hold for a couple seconds. That usually does the trick.
mgmarsh39255.00
      04-03-2018, 04:40 PM   #3
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
Thanks! Will go try now.
      04-03-2018, 09:45 PM   #4
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
Didn't work for me
      05-06-2018, 11:49 PM   #5
evanescent03
evanescent03's Avatar
1032
Drives: '24 M3 CS; '22 GT4
I just bought a used 2016 which is doing this.. they told me it was related to the key programming... however, the key was reprogrammed and it still is doing it but not all the time.
I am taking it back next week or month when I can. It helped me open the door to close it once or twice but hasn't worked every time. The issue itself doesn't happen EVERY time ... but has definitely been the majority.
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
mgmarsh39255.00
      05-07-2018, 06:27 AM   #6
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
Yes, exactly the same issue! Please let me know what they say when you take it back.
      05-09-2018, 11:12 PM   #7
evanescent03
1032
Will do
      05-09-2018, 11:42 PM   #8
spikespiegel
Drives: BMW M6 comp
i've had this issue on my 14 coupe.. I was told the regulator needed to be reset, and they did that, but still didn't help. Then they said they ordered new parts to get it replaced under warranty. Still haven't done that.. Its a bit annoying but not too big a deal lol
      05-26-2018, 12:13 AM   #9
evanescent03
1032
Regulator and motor need to be replaced. Car will be sleeping in the service lot until Tuesday or so until the motor comes in. Hopefully that fixes it!
      05-30-2018, 03:12 PM   #10
hirkaismyname
Drives: F06 CP GC
did it work evanescent03 spikespiegel ?
      05-30-2018, 03:25 PM   #11
BMWDriverX
Drives: G12 750i X-Drive
My car was doing this and I brought it in for service, they updated the software and the trans software as well, and it has not done it since.
      05-30-2018, 03:50 PM   #12
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
Good to know. Do you have any details on the software update they used?
      05-30-2018, 05:52 PM   #13
BMWDriverX
I do not, I took it in 2 weeks ago and they said this is the most current new software for my car and transmission
mgmarsh39255.00
      06-01-2018, 03:17 PM   #14
evanescent03
1032
Like a charm!! Been testing it to make sure ... with all the fancy features, it's sure a relief to get basic functionality back!
      07-18-2018, 11:20 AM   #15
drewdogg77
Drives: 2015 650i GC
2011 BMW 550I  [0.00]
I had my window motor replaced by the dealer,,,first time the did a reset which didnt work, second time replaced the motor,, fine now
      09-28-2018, 08:24 AM   #16
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
Just to update everyone, I had 3/4 replaced, and now the 4th is hopping, so back to the dealer!
Be sure to test your rear sunshades before you leave... This happened to me the next morning. Apparently they forgot to hook it back up properly. Dealer did replace the sunshade and tint at no cost of course.
      07-31-2019, 01:24 PM   #17
hirkaismyname
Drives: F06 CP GC
This issue has popped up on my new F06. I was told it may be a programming issue. It's a'17 with 13.2K miles on it -- should be covered by warranty -- but I was curious to know what exactly I should tell the dealership?
My right window at times doesn't even register the input to actuate the motors -- meaning, when I push the window down button, the window doesn't even move.
Any help with how to approach this issue with the dealership would be great.
Thanks!
      08-01-2019, 04:50 PM   #18
Qsilver7
Qsilver7's Avatar
This issue has popped up on my new F06 ... I was curious to know what exactly I should tell the dealership?
Thanks!
See posts #9, #14, #15, #16 for the "bounce-back" issue
