01-10-2024, 12:51 PM | #1 |
Rep 5
G32 Emergency call - code out
So I have the 'Emergency call is not available' message perm on my dash. How can I code this out using Bimmercode? All of the forum messages i've seen reference a different advanced menu option. All help is appreciated.
01-10-2024, 05:16 PM | #2 |
Rep 7,489
Isn’t that an error warning? If yes, I would think diagnostic software is what would be able to clear this error. Do you have the Bimmerlink (sister app to Bimmercode)?
For example, you can code the camera warnings OFF…but if your rear camera or another camer were to have an issue/malfunction…you’d still get a warning that there’s a fault/malfunction. Coding a notice ON or OFF…is different from an error/malfunction warning that would be taken care of with diagnostic software..
01-11-2024, 01:19 AM | #3 |
Rep 5
Many thanks for the reply. Indeed it's quite well documented for other models how to use bimmercode to alter a parameter in the ECU to trick the car in to never showing that error. The battery in the module needs replacing for the SOS element to work. But I don't want to go to the hassle of replacing it just now as its user the headliner. I have bimmercode, I just don't know which menu to use. The g32 menu options are different to the g30 which seems to have been discussed many times in other forums. It doesn't help that all of the advanced menu options are in German.
01-11-2024, 11:00 AM | #5 |
Rep 7,489
Thanks for the update and additional info.
