      01-07-2016, 08:10 AM   #23
pinguhk
pinguhk's Avatar
31
Drives: LCI F06 640i Msport
At last over 6 weeks of waiting. My late xmas present Bavsound 8" subwoofer arrived.
I will install them at weekend and I tyr and take some DIY photos and let you guys know how good or bad they are after install.
2015 640i GC M Sport
      01-07-2016, 04:38 PM   #24
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
did it come with the gaskets?
      01-07-2016, 08:03 PM   #25
pinguhk
pinguhk's Avatar
31
NO!!!
I emailed them and they will not send overseas so pissed.
I hope I can find the gaskets locally.
      01-07-2016, 08:31 PM   #26
Downfourit
Drives: M6 Gran Coupe`
Originally Posted by pinguhk View Post
NO!!!
That's stupid.. How did they send the speakers overseas but won't send the gaskets? If you paid with a credit card I would dispute the charges and/or negotiate a large discount as they did not send you a working product.
      01-07-2016, 10:00 PM   #27
lsturbointeg
NO!!!
wow! are you serious!!! Di** move from Bav!
      01-10-2016, 02:56 AM   #28
pinguhk
pinguhk's Avatar
31
here is the DIY step by step of the BAVSOUND subwoofer install.
http://www.6post.com/forums/showthread.php?t=1213301
      01-10-2016, 07:42 AM   #29
WWnyc
Drives: 2014. 640 ix Vert
Some of us are still waiting to hear about the "simple 2 channel amp" addition that might help without going thru changing out the subwoofers
      01-10-2016, 03:40 PM   #30
lsturbointeg
never heard of it? do you have a link?
      01-10-2016, 07:47 PM   #31
WWnyc
From a Bimmerfest post:
#15 Report Post
Old 12-04-2015, 05:58 PM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2015 320i
View My Garage
The RF woofers are 4ohms, your OEM woofers are 7ohms. Your OEM amp is not stable at less than 7ohms.
My suggestion for HK systems with lack of bass is to add a 2ch aftermarket amp to the OEM amp with about 150W RMS per channel. No need to replace the OEM woofers.
Once you hear the OEM woofers with aftermarket power you will know what I am talking about.
      01-10-2016, 08:31 PM   #32
pinguhk
pinguhk's Avatar
31
yes I hear this too but that will cost even more, seen some plug and play amps for over $950usd and cheaper to change subs.
As you can see the OEM subs are very cheap made and I dont think you will get good sound out of them also the design is different, it is upside down compare to the Bavsound sub.
Bavsound also do a amp for our 6er
      01-10-2016, 09:22 PM   #33
lsturbointeg
#15 Report Post
Technic's Avatar
Test... 1, 2 ,3
View My Garage
how would you get the signal for the sub from the OEM amp? yes, you can add an aftermarket amp but i'm guessing Technic would have to make a harness to send a sub signal to the amp from the oem amp? not sure how that would work? in my case Bimmertech amp has already solved that problem...not sure how you guys would do that on a HK system?
