      04-28-2015, 09:00 AM   #1
Sharif507
Drives: M6 F13 2014
whats the widest wheel setting for 20s on m6?
hey guys, im looking to switch my rear tires to wider setting, the front tires on my car are almost gone, but the rear tires seem to be holding up strong.
could i switch to 295/30/20 in the front (current rear tires) and whats the widest i can go in the back without rubbing?
i do have spacers 10mm in the back and 5mm in the front.
sharif
      04-28-2015, 09:14 AM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
sharif
With respect to rim & tire specs, the widest tire for 9" rim is 275 and the widest tire for 10" is 295... Your M5 343M is 9" wide front and 10" wide rear.
M6 343M is 0.5" wider both front and rear so you can go up to 285 front 305 rear (my current setup on rear)
      04-28-2015, 09:14 AM   #3
bshep604
Drives: 2014 M6 GC
When considering + sizing wheels or changing tire sizes I always start with a decent wheel/tire size calculator. Something like this:
http://www.rimsntires.com/specspro.jsp
In addition to recommendations from those who have experience with actually trying out different sizes. My .02
      04-28-2015, 09:20 AM   #4
Sharif507
Drives: M6 F13 2014
thank bro, so 315 and 325 in the rear is not doable?
      04-28-2015, 09:39 AM   #5
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Not with your current rims. For 315/25/20 you need at least 10.5" width and for 325/25/20 you need 11.5"
      04-28-2015, 09:51 AM   #6
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
How wide of rims could you run on the front without issues? Crazy talk, but could you (on the M6) move the rear 10.5" rims to the front, with some spacers, and throw 12" rims on the rear and run something like 305s in the front and 325/335 in the rear? Or is that a terrible idea for 100 reasons?
      04-28-2015, 10:44 AM   #7
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
It's definitely terrible idea
They have different ET. In case of M6, the front is 31 and the rear is 19
Using the link in post#3 the rear rims with 305 tires installed up front stands 0.3" deeper inside and 1.3" outside. 0.3" inside is not a big deal but 1.3" outside is about 33 mm. It's like you use 33 mm spacer on the stock front wheel. Almost the similar thing on rear. Even if you don't experience rubbing (which I doubt), having 4cm wider tire up front (and rear), will change everything as far as steering feeling and handling. Your car will turn to be a bus at corners
      04-28-2015, 10:46 AM   #8
double trouble
Drives: E60 m5
I'm running 325s on a 21x12 rear, and that's the absolute farthest I would go without being concerned about rubbing big time.
http://i154.photobucket.com/albums/s...pskqsrt4bu.jpg
http://i154.photobucket.com/albums/s...psyvn3jvab.jpg
Best,
Ben
      04-28-2015, 10:50 AM   #9
Sharif507
Drives: M6 F13 2014
thanks a lot guys!
      04-28-2015, 10:57 AM   #10
devondragon
That's what I figured Thanks!
      05-13-2015, 03:35 AM   #11
chask
Drives: 2014 M6 GC
Best,
Ben
What is your wheel offset? Did you roll your fenders or are they stock?
Does anyone know if there is any downside to rolling the fenders?
      05-15-2015, 05:50 PM   #12
mrainv23
mrainv23
mrainv23's Avatar
Drives: 2014 BMW M6 Gran Coupe F06
Just put on 15mm spacers from sonic tuning. Perfectly flush with a +25 offset wheel.
2014 BMW M6 Gran Coupe F06/M Performance Black Grille/20% Tint/ Exec Package/ Driver Assist Plus/ Black on Black
Sold-BMW 550i F10/Dinan S3/ Eisenmann Race Exhaust/ Vossen CV3s
      05-15-2015, 05:52 PM   #13
mrainv23
mrainv23
mrainv23's Avatar
Close up: I am also running 305s on 10.5 wheel.
      11-11-2015, 08:11 PM   #14
aznkuja328
Drives: F86 X6M F80 M3 991 GT3
quite confusing... So, the final offset after the spacer is et10 on a 10.5" wide wheel and 305 tires on the rear to achieve the flush look on your car?
      11-12-2015, 11:09 AM   #15
PRican//M614
Drives: 2014 BMW M6, 2015 BMW X5...
I have 21x12's on my 14' M6.....
      01-02-2016, 05:38 PM   #16
mrainv23
mrainv23
mrainv23's Avatar
Yes you are correct 10 is new offset
      01-04-2016, 12:51 AM   #17
Twitch Massacre
Twitch Massacre's Avatar
Drives: 2015 BMW i8
I12 BMW i8  [0.00]
F13 BMW M6  [0.00]
sharif
I ran 325s on a 21x12 ADV1 wheel in the rear. If you want to go any wider than a 305 you need to ditch the stocks. Spacers can only do so much. To be honest nothing beats a custom built forged wheel when it comes to aggressive wheel/tire fitment.
H&R Springs
21" ADV.1 ADVNL2 MV2 CS Wheels
Coming Soon:
2016 BMW M4 GTS De-Winged and Bagged on 22s
      01-07-2016, 04:56 PM   #18
Rob@StrasseWheels
Rob@StrasseWheels's Avatar
458
Drives: 2023 BMW G80 M3 Comp
We just built a few 20x9.5 and 20x10 front and 20x11.5 and 20x12 wheels for different BMW M6 applications. Tires varied from 315 rear to 325 rear.
@Strasse_Robert | (786)701-3649 | Robert@StrasseWheels.com | www.StrasseWheels.com
      01-07-2016, 06:27 PM   #19
gandalfthewhite
Drives: F12 M6 Convertible
and 21x10.5 ;-) front 285 (its maxed)
also 21x12 rear 325 (wheel could probably be .5 wider but no 335 is available)
thanks again Robert!
use this https://www.rimsntires.com/specspro.jsp
      01-17-2016, 12:19 AM   #20
ARC550
Drives: M3, X5, 720s, X5, 750xi
Size on 10.5" depends on what tire make/model
The Toyo R888 you can do 315/30/20 on the rear. The 10.5 is within their spec.
I have these sitting in my garage and can't wait for winter to be over!!
      01-17-2016, 12:23 AM   #21
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
very nice!
      09-02-2016, 01:13 AM   #22
gr112884
Drives: 2016 M6 Gran Coupe
sharif
Can you send me some pics of you m6 with spacers? I wanted to do the same? Thanks
