      02-21-2016, 01:32 PM   #1
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
Question How to store for 6 weeks
I'm going to be traveling for ~6+ weeks and I wasn't sure what, if anything, I should do for the car. She'll be parked in a nice dry garage.
Should I put her on a battery tender? If so, where do I hook that up, the jump start contacts, or?
I'm assuming that's too short a time to worry about fuel stabilizers.
Anything else I should think about?
Thanks!
      02-21-2016, 09:52 PM   #2
2007 to 2016 M6 Cab
Drives: 2019 M2 Competition HS
Thanks!
When I store Princess ... I just hook up the "BMW Trickle charger" to the the battery terminals in the trunk ... she is usually hooked up for 4 to 5 months ... not an issue. You can nearly shut the trunk on the electrical cord.
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV
Past Cars:
2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban
      02-22-2016, 09:07 AM   #3
devondragon
Thanks! Is this the charger you have? http://smile.amazon.com/BMW-advanced...dp/B00N55PDUY/
I found this, supposedly from BMW:
""On vehicles with IBS, recharging the battery directly at the battery terminals could lead to a misinterpretation of the battery condition and even unwanted Check-Control messages or fault memory entries.
If the battery is recharged while installed, it must be recharged using the jump-starting points...in the engine compartment.
Only then can you be sure that the recharging is correctly recognized by the vehicle electronics on vehicles with intelligent battery sensor (IBS)""
So sounds like under the hood is recommend?
      02-22-2016, 10:03 PM   #4
2007 to 2016 M6 Cab
No, it doesn't look like that one ... I did purchase it directly from my BMW dealer and has a BMW Logo on it ... and they recommended that it be hooked up in the trunk ... I have done so with no issues on this M6 and my last M6.
See what your dealer has for chargers and their recommendations.
Both locations sound good ... but go with the best info your dealer can provide as they will be the ones dealing with any warranty issues.
Current Garage:
Past Cars:
      02-23-2016, 06:49 AM   #5
devondragon
Good point! I will make sure to see them before I leave. Thanks!
      02-23-2016, 07:17 AM   #6
ilidon
ilidon's Avatar
Drives: F13 M6
2009 335i  [7.00]
If you have a trickle charger, connect it ito the batery ports located in the engine bay. Look for the red terminal on the upper left hand corner (+) and the metal sticking out near the fender (-)
      02-23-2016, 07:18 AM   #7
2007 to 2016 M6 Cab
      02-23-2016, 10:58 PM   #8
Phatcat
Drives: BMW M5, X5M
Thanks!
If it's just 6 weeks then I don't think you need to do anything. But if more then probably should hook it up.
      02-24-2016, 04:38 PM   #9
HoustonRider
big pimpin
Drives: 2014 M6 GC and 2015 4 GC
bingo. I don't think thats a long time. its just 6 weeks.
2014 //M6 GC
2015 750Li
2015 435i GC
