      03-13-2024, 07:51 AM   #1
Bweis99
Drives: 2009 650i
2007 M6 vs 2009 650i wheels
Good morning,
I would like to swap these wheels and tires. I prefer the wheels on the 650i over the M6. Is this possible or is there going to be a concern with offset? Thanks in advance.
      03-13-2024, 12:31 PM   #2
Staszek
Schumacher
Staszek's Avatar
791
Drives: E30 325is,E93 M3,X7M50,F06 M6
Originally Posted by Bweis99 View Post
Good morning,
Which 650i wheels are you running? They should be ok since you are going to a less aggressive wheel. The only thing I would worry about is if you have 18s since the less aggressive offset of the 650 wheel may have brake clearance issues.
The offsets between the M6 and 650 are close, but the wheels on the M6 are wider.
I know you like the look better but you will lose some width since the rims are not as wide, probably not enough to make a difference on the E63s since they dont have a ton of torque of the line.
I attached the different setups for the 650 and the M6 so you can see the difference.
