      02-25-2013, 07:47 PM   #45
neversummer78
neversummer78's Avatar
Drives: 4 wheels....
Originally Posted by mlai View Post
Neversummer78 and Andreo,
My 650i GC also felt a tad more responsive with the mod. My friend who test drove the car last night also mentioned the same and asked what I did (I didn't tell him the mod).
Did you guys feel your 650i a bit more eager to go and more responsive after the mod? Or am I and my friend just hallucinating........
I feel that it is a little more aggressive but could just be from angrier exhaust note.
      02-25-2013, 08:47 PM   #46
mlai
mlai's Avatar
Hong Kong
168
Drives: 650GC/E93M3/Lexus LS600HL
For me, difference is definitely there. I live on a small hill so I have to go up the ramp everyday. And that's where I can definitely feel a bit of a power gain. In short, comfort mode is like sport mode accel up ramp now
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      02-25-2013, 09:16 PM   #47
neversummer78
As long as you are happy and nothing is broken, I am happy.
      02-26-2013, 01:06 AM   #48
andreo
BMW Enthusiast
andreo's Avatar
Macao
20
Drives: Citrin Black 650i Coupé (F13)
I did not pay too much attention to the responsiveness but I did notice that the engine drops below 1000 rpm a couple seconds quicker at cold start than before. So I won't be surprised if it did improve responsiveness but it's a little difficult to tell for me as the vehicle is still relatively new. I need to get to know her better first.
Overall, the exhaust note is more sonorous but the difference is not as significant compared to the same mod on the E92 335i I used to own.
      02-26-2013, 02:40 AM   #49
mlai
mlai's Avatar
Hong Kong
168
From the technical drawing, the actuator is right on the exhaust. If you can unhook it and zip tie the link/arm that control the flap, then that should do the trick. However, I think the flap does more than just the sound but also control the back pressure. If you keep it open all the time the torque might be affected a bit. Probably not too bad since it got a lot to spare to begin with. I will try to look into it next weekend unless you get it working and wanna share some photos before that.
BTW, for turbo cars, back pressure does not help performance at all. In fact, the actual back pressure is not advantages to NA engines either. Let me explain a bit from researching on the net.....
Let's start from NA (yes I know. We are all turbos now. But bear with me for a little....) Back pressure actually prevents exhaust gas flow and and impedes proper scavenging on the engine cylinder cycles.
What the NA engine needs maximum exhaust gas VELOCITY, so that it creates temporary vacuum which sucks out residual exhaust gas still in the cylinder. The easiest way is to squeeze the gas in a tube that is at the correct diameters. I did say correct, there is a sweet spot to tune the exhaust speed. If the pipe is too wide, the gas slows down and scavenging becomes less effective as the vacuum is not as long. If the pipe is too narrow, well, you have excess back pressure which makes it more difficult to suck residual gas out from the engine.
This is also one of the reason why, when one simply replace exhaust systems on a NA car with bigger pipes, people will generally feel lost of low-end torque because the exhaust at low rpm is not moving fast enough for scavenging, hence engine is less efficient. Improper tuning and exhaust matching can also cause exhaust gas moving too fast, which sucks not only residual burnt gas, but also sucks out some of the air that just entered the chamber and unburnt fuel. So, in NA, simply replacing exhaust without adjusting engine tune almost always results in less performance.......
Now for Turbo cars like ours, scavenging the exhaust gas out of the chamber is less of a problem. Why? Because we have blowers force feeding the chamber with compressed air!!!! And contrary to what people may say about back pressure "creating loads on the turbine to shorten spooling", that is not at all correct. The turbo units essentially is a turbine ran by differences between intake pressure and outflow pressure. The intake is from the exhaust manifolds from the engine and the outflow is everything back from the turbine. So if you create back pressure behind the turbine, it will make the turbine harder to turn, thus in turn makes turbo lag worse.......
So the bigger the exhaust pipe from turbo-back, the lower the pressure (limiting up to atmospheric pressure in theory) at the turbine outflow port. In theory, the turbine fan should be easier to turn, and thus lowering spool time of the turbo?
Is my understanding somewhat correct on this?
      02-26-2013, 12:59 PM   #50
neversummer78
I can agree to this reasoning. I upgraded exhausts and headers on my 2 previous NA cars, and I notice poor low end torque on both cars. That isn't the case for this car. First, I was thinking that it might have to do with twin-scroll turbos which allow engine to be responsive at low rpm/less exhaust gas. But, it seems like exhaust systems on turbo cars are really just for noise suppressing, filtering backfiring noise and droning.
Now, I wanna get X-Pipe for this thing, but something I can swap in and out myself without visiting the shop.
      02-27-2013, 01:29 PM   #51
Bönz
Bönz's Avatar
Drives: 2018 M5
Only the S63 engine has twin scroll turbos. The N63 settles for regular turbines.
The analysis re exhaust is correct. However, peak HP is controlled by max boost. There is no way holding open the exhaust flap is making more power. Perhaps there's a slight reduction of back pressure reducing turbo lag, but I doubt it's enough to feel.
The louder exhaust note is just fooling your mind.
      02-27-2013, 01:37 PM   #52
neversummer78
That's right, N63 is regular turbines. Fast enough as is, so I am still happy.
      02-27-2013, 08:09 PM   #53
mlai
mlai's Avatar
Hong Kong
168
I am happy to be fooled in this case I am not saying the car has loads more power, just that the car is a tad more responsive and eager to go, especially at the lower rpm range. Possibly due to reduced turbo lag at very low rpms.
      02-27-2013, 09:34 PM   #54
neversummer78
Let me know if check engine light pops up because of that mod, so I can quickly remove it before sending it to the dealer.
      03-04-2013, 07:53 PM   #55
markeh
Russian Federation
12
Drives: 2013 CB 650xi GC
Do I have very large hands or is it nearly impossible to properly put this ziptie on?
Can you guys explain how you did it comfortably?
Thanks
      03-04-2013, 08:21 PM   #56
neversummer78
Thanks
If you jack your car up and lay on the ground while doing it, then it would be easier. Another trick is, pre-bend the zip tie, so you don't have to squeeze your hand through the crack between exhaust and diffuser to get it loop back.
      03-04-2013, 08:28 PM   #57
markeh
Russian Federation
12
So I just push the flap in with something and then tie the control arm to the nearest stationary piece? Holding the loop sounds effective, gonna hunt for a jack now asking all my neighbors since I'm in an apartment lol
      03-04-2013, 08:43 PM   #58
neversummer78
You don't really need to jack car up unless your car has been lowered, or you are having tough time then jack it up will ease the access a little from what I see. I did not jack it up when I did mine.
I used a piece of stick to yank the flap open and hold it open while installing zip tie. When flap is in open position, actuator arm will be in retracted position where you can loop zip tie around the link from actuator to the flap to keep it open. If you have trouble with zip tie which I did, then you can use some sort of steel wire instead. It would be easier with steel wire because you can easily bend it and it holds shape. Zip tie keeps swinging back even after I pre-bend it.
      03-04-2013, 09:52 PM   #59
markeh
Russian Federation
12
Jacking the car up helped, I just have pretty big hands haha.
It sounded meaaannn on the cold start, and now at normal cruising it sounds a little louder with the same tone of stock, however it screams when you pass 3-3.5k+
Thanks
Edit: Heres the result! http://a.yfrog.com/img14/2792/n3axka...ojnamdnphn.mp4
      03-04-2013, 10:33 PM   #60
neversummer78
Thanks
Nice, congratz!
      03-05-2013, 01:04 AM   #61
andreo
BMW Enthusiast
andreo's Avatar
Macao
20
It could get quite painful on the fingers holding the actuator while manipulating the zip tie in those tight crevices between the exhaust tip and the muffler. Glad that you pulled it off finally. Enjoy the result.
      10-15-2022, 01:22 PM   #62
dadaabmw
dadaabmw's Avatar
Drives: BMW 650i, BMW M3, BMW X3
650i GC - Exhaust note - Cold Start
Update!
I used zip tie and keep flaps on both sides open. It is sounding much better at low speed.
I’m thinking about doing the same to my 6er. How has the zip tie held up? Any melting?
      10-15-2022, 02:26 PM   #63
neversummer78
Zip tie was holding up until BMW NA bought the car back from me 2 years later through lemon law.
