      03-25-2024, 02:33 PM   #1
Walt White Coupe
Walt White Coupe's Avatar
222
Error Code 132408 VANOS Valve
So, I got a check engine light on. Code 132408
VANOS solenoid valve, exhaust: Intake camshaft not in locking position at start up.
Mileage: 40,000
Car seems to run fine. Is this something I should be concerned about or can I just live with it?
      03-26-2024, 01:47 PM   #2
Walt White Coupe
222
Car starts up fine, no rattles, holds constant rpm at idle & runs smooth. For the time being, as long as it doesn't throw more serious codes, I'm just going to just ignore it.
      04-03-2024, 10:16 AM   #3
tpsc3crt
Drives: 640XI F12
Why not try cleaning both of your VANOS solenoids with brake cleaner? I hear its relatively easy. Worst case i believe theyre around $75-$100. Normally if they're clogged up you will notice jerky acceleration or rough idling.
      04-03-2024, 12:50 PM   #4
Walt White Coupe
222
From what I've seen in youtube videos, they are a bitch getting to and removing them on the V8 engine. Considering that for a couple hundred dollars, I'll just replace the two of them on one side and have an independent garage do the work at some point.
The other code: 132608: VANOS solenoid valve exhaust 2: Intake cam not in locking position
So far the car is just running normally.
      04-18-2024, 06:51 AM   #5
Walt White Coupe
222
Ended up buying two standard equipment BMW parts for $450 two weeks ago and anticipated having a local independent BMW shop install them at some time in the near future. Today the check engine light came went out. Will be returning the parts.
