      09-08-2023, 05:40 AM   #23
suj999
9
Drives: F06 640d M Sport, F10 520d SE
Originally Posted by martin mustang View Post
Just like my car, a new Window Motor was needed, it was covered under warranty.
How did you manage to convince them?
As mine doesn't do it when the dealership is testing it
      09-08-2023, 05:33 PM   #24
FlyinLowSD
Tinker
Drives: 2017 640i GC,1994 300ZX MT 2+2
Video recording the issue often helps. Nothing seems to misbehave in front of the mechanics!
      09-11-2023, 03:03 AM   #25
suj999
9
Thanks, 2nd attempt with video evidence.
Let's see
      09-11-2023, 06:41 AM   #26
suj999
9
Let's see
Failed at trying to get it fixed!
Useless service at Steven James Enfield this time.
Supposedly if it doesn't do it when the person booking it tries, then it's not a fault!
What's the point of this AUC warranty?
      11-02-2023, 10:53 AM   #27
ACCD
ACCD's Avatar
Drives: F13 650i
My driver windows will do this 2-3 times per year. When under warranty, the dealer did a fix, however it came back. I suspect this is over sensitive software. As I can reset the window by cycling it up and holding the button on setting the up limit and then move it down setting the stop limit. Seems to work for about 4 or 5 months and then I need to do the up and down-y thing again.
      01-14-2024, 11:10 PM   #28
Jarmaha
Drives: BMW F13 640i
Originally Posted by BrandChemist View Post
I have the same issue. But I have a weird symptom that may lend a clue as to whats really wrong. My windows work perfectly fine WHEN THE CAR IS MOVING. Its only when I am stopped do the driver and passenger windows go bananas with a mind of their own. I also have to go up in 2 inch increments in order to get them all the way up.
I thought I was a genius when I considered the alternator may be why the windows work when the car is moving, so it MUST be a battery problem. Checked the battery, and sure enough, it was only producing half power. I MUST be right! Right? $300 later with a new battery and the windows are still wonkadoo. /facepalm
The stealership says I need 2 new window motors, but why would the motors be broken if they work perfectly fine while driving?
Hi, did you manage to fix the problem ? i have excactly same issue... as soon as i step on gas the window will close perfectly
      02-17-2024, 03:42 AM   #29
bossturbo
Drives: F12, F45
Same problem
Hello All,
I have the problem on my passenger window.
The worst part is when I press-long on the remote to close all, the window rolls down and I think I have the car closed, but not.
Did the reset procedure worked for anyone?
I see some grease marked on the window... can be a roller?
Did some good cleaning helped someone?
Thanks!
      02-20-2024, 12:07 PM   #30
suj999
9
the only proper fix is a new Window regulator and guides.
They are not cheap.
      03-17-2024, 04:37 PM   #31
PixelVogue
22
I have the issue on my drivers door, press 1 click to roll it up but gets 3/4 up and stops, you have to press the switch 2/3 times to get it up. Its like it gets stuck or thinks there is something in the way!
Might have to get warranty on it and sort it lol
