      11-12-2022, 02:46 AM   #1
paul_80eighty
Drives: BMW M6 F13
Cyl 7 Misfire, DTM at WOT - Plugs/Coils/injectors done already
Hey guys, I’ve owned my F13 M6 for around 8 months now and love it. However I’ve run into an issue that started about a month ago.
When in 2nd gear or higher, I noticed a stutter/hesitation when doing a pull. This problem started gradually. The first time it happened I wasn’t even sure if I fully noticed it. The next time, it threw drivetrain malfunction at me. This would happen at 75% throttle or more.
For context, I’ve got aftermarket charge air coolers, Charles’s DPs, fatback exhaust and an ECU tune.
So, I changed out my plugs to NGK 97506 1-step colder gapped to 0.024. This did not fix the issue, although it was time for a plug change anyway. Then, I changed out ignition coils. This did not fix the issue either. Finally, I changed out the injectors in bank 2 (since the misfire is cyl 7). I really thought this would fix it, however it did not. I did notice a slight improvement - I had to drive a bit harder for it to throw the code again. But regardless, the issue persists. The only code being thrown is cyl 7 misfire.
I’ve tried reverting to stock tune without success. But in doing this, I noticed it took driving the car a bit harder as well to get it to throw the code - which makes me think it’s still a fuel system issue.
Idle is smooth, and driving the car normally I don’t notice anything wrong whatsoever. It could be so many things, but wanted to see if anyone has had this issue before where there’s a persistent in one cylinder only under load heavier load (1st gear pulls still rip to redline with no noticeable issues). I haven’t noticed any unusual smoke from the exhaust or any unusual smells either.
Thank you for any input!
      11-12-2022, 12:48 PM   #2
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
After the new injectors were installed was the calibration info updated on the DME? Could possibly be HPFP or LPFP. Hit the F10 M5 Engine forum and search on there for misfires, a treasure trove of info on misfire troubleshooting.
      11-12-2022, 09:01 PM   #3
M6Roar
Drives: '14 M6GC
lower the gap in that cylinder to 0.022 and see if it helps
      03-01-2024, 09:06 PM   #4
AbedChaar
Drives: 2016 BMW M6 gran coupe
I am having same issue. did you find a solution? please share
Tags
coils, fuel, ignition, injectors, misfire, s63tu, system
